You can get any of the pumps with a standard or rotated flange, just depends on the model number. I got those nifty Webstone isolation flanges that rotate, so you can use whatever. Havent had to use them yet for a pump change, but Ill bet they will be nice when I do.
One more thought... Rather than the balancing valve (which I know restricts the flow in your injection loop) what about partially closing a valve right after the pump? This would increase the head, reduce the flow, and potentially trick the controller into keeping things above 50% instead of the dip.
You are right that its potentially a hydronic issue coupled with the lower % driver of the pump. I would say to hook up the 008 to the controller without connecting it to the piping, and see if it will still spin at 30%. (Thats probably not so good for the pump unless you can hook it up to some temporary piping and pump into and out of a bucket or something). It might help isolate if its truly an electronics issue, or if the hydraulic effects of your system are also playing a large part.
