I'm a June burner now
I was going to clean it out for the summer but she hasn't put it on my to do list yet;lol
Reactions: bogieb
Was burning last night into this morning. Best sleep I've had for a while with the distribution fan and doorway fan covering the noise of traffic.
It was cool last night car was reading 52 on the way home
Reactions: bogieb
I gave mine the final cleaning and blocked them off from the outside. Damp rid is in the firebox. Can't believe how late we ran them this year.
yup.
burning right now.
*short burn, but a burn nonetheless.
Just lit the stove again this morning, 65 F in the house and the wifey was cold.
You guys in Maine and Canada are hard-core, still burning. ;) But it's been cooler here in NH also, hope you get good Summer weather soon.
Stove is clean, flue block plate is capped, stove parts are being sanded / painted, OAK is being installed .. We're done for awhile here.
I'm a June 28 burner now - and may be a June 29 burner. We'll se. If the sun comes out and warms up the house, I won't need it, but if it stays anywhere near what it was yesterday, I'll be turning the thermostat/stove back on (turned it off when I got up this morning).
Reactions: St_Earl
I was a June 29 burner, it was 58 in the house.
I was a June 30 burner - took the chill off this morning. temps outside heading back up, so I'll pull the plug (again). Maybe I'll actually get around to a good cleaning over the holiday weekend.
i just missed being a july burner. burned a little two or three days ago.
today the spirit moved me and i started the year end cleaning.
strapped the shop vac to the ladder and vacuumed the vent. it's about a 4 foot horizontal 4" pipe, and i burned close to six tons this year.
i didn't vacuum it once and it was nowhere near clogged. maybe if i had 3" inch venting i'd be more concerned. but this is the second year in a row i haven't bothered with it till year's end and it works just fine for me. no detriment to burn quality at all.
my old drill bit the dust on it's last project, so tomorrow i'll get another and run the linteater, pull the motor and put the new one in (the current one will be the spare) and replace the burned out igniter with the lower wattage one that should last longer. getting tired of replacing them.
clean up and dust out inside the cabinet, room blower, etc...
no paint needed this year. just going to spray stuff down w/ graphite and or wd40 where needed, put the damp rid in, plug the vent and OAK and mostly forget about till late september.
^LOL! that's not even long enough to forget. ;lol
Usually clean the stove in May Lit the stove this am Yep 2nd day in July it was 48 here this am barely makes it to the upper 60's during the day for the last 2 weeks. Normal is 80 degrees when we get up and then it gets hot by noon.
Reactions: bogieb
Reactions: tiger
Thanks. Of course, now I have the 4LB tub from Amazon, can I just take some amount of that and put in some container (plastic cup) and place it in the stove? That tub is NOT going to fit, even removing the pseudologs.
I get it at Home Depot. Comes in a little tub (10.5 ounce). Only costs a few bucks and keeps the rust away. It gets very humid around these parts and even though the stoves are sealed up moisture can find it's way in.
http://www.homedepot.com/p/DampRid-...-Refillable-Moisture-Absorber-FG01K/100392067
I would get the small tub I posted above and use your big tub to refill. The small tubs are refillable. They have a small basket in them that the stuff sits in that allows the collected water to drain and sit in the bottom of the tub. Take a look at one of the small ones and you will know what I mean.
Reactions: CleanFire
