Get it with the soapstone. Tom could use the extra money for retirement.
If the transfer rate is slowed there will be more heat in the box..thus stronger draft.The transfer rate is not affected at all. Added mass has no effect on the rate of trans, just the time.
yeah but the rock is stationary and can only hold so much.Not at all. That rock is gonna soak heat just like the water. A temp differential thing Dr. Heat.
Yes, ash is a good insulator. There are reports of coals staying hot in the ash can a couple days after a stove cleaning.
How do stoves like this work with less than ideal wood? In other words, will the cat light off and work if the wood is over 20% moisture? My goal is to get 3 years out, but right now I'm struggling to make 2.
we didn't want the andirons
You ever see a soapstone lined furnace?
Ever notice how thin a heat exchanger is ?
