Too much leakage behind the plate??
The baffle should rest on the small shelf if you have one under the outlet.
It should be angled upward at the front aimed towards the lower bend in the top plate.
The space between baffle and top should be about 2 inches. The pics below are just over 2" with an 8 inch plate. (this was for a masonry flue - you can go the minimum just under 2" with insulated flue)
Baffle height at front can normally be adjusted by sliding bricks on sides forward or back to raise and lower front edge of plate.
It should direct heat to front plate or lower bend.
My highest temperatures are just in front of lower bend.
