bcfarms
I've got a husky 346xp as a limbing saw but for an all around saw I'm hooked on the Makita/ Dolmar DCS6401. I've got two
What ya want for the 036? Like I need another one, but well you know. A C
There is a Nice 360 Pro with case for $350 in my locale on CL ........ Tryin hard to resist?
(If I sell my 036, then I could...)
There are some nice saws on the used market. Just gotta strike while the irons hot![]()
Absolutely no reason to abandon your 036 (Pro?) for a MS360. MS361, maybe, but I wouldn't, especially as clean as your 036 is.
What ever you do dont waste your money on a ms390 . Maybe mine was a fluke ,but it was just a plane pig. Power to weight ratio is bad. Could'nt pull a 24 inch bar if it tried boogged down alot. 18-20 was ok. My buddy's 290 and 260 ran right with it. The ms260 is a great bucking and limbing saw that wont break you. Like some have said the ms260 026 used is a good way to go. not heavy and good power.
I like a small to mid-sized fast saw 346xp or 260 is what i'd be looking at. Good luck with your purchase.
I know there the same. Its tamato - tomato.
Wont hurt to look..... It may be cleaner than my 036 (be hard pressed to find one cleaner) and the 360 is slightly newer and its a Pro. Which makes it, no different really.
Its gonna have to truly check out, to even be considered. But.... Ah hell, I have a problemStill calling.
I have one of those same Craftsman saws that was given to me, 18" bar. I cut about 6 cord a year average. It has been a surprisingly very good saw. I leave the top cover off so I can run it hard and it doesn't get too hot. It has a full large air filter so no worries. I learned to keep the carb clean and adjusted so it runs strong. There is no massaging this one. I got rid of that sissy chain and put a real chain on it which made a huge difference. I hand sharpen it, keep it out of the dirt when I can, and I hate to say it but it actually cuts faster and stronger than my dad's small Stihl, also kept up well with another guy with a small Stihl. Yes I am in Stihl country too. Been cutting 7 years and no problems with kickback, I think it is more in paying attention to what you are doing. On a cold engine I either shoot it with starting fluid for instant start, or just pull 5 or 6 times and it starts. Warm engine starts right up and it runs till the tank is basically dry. Actually my only gripe is the gas cap, for some reason the threads have tightened up to where it takes channellocks to turn it. And the bar adjusting screw, not really a gripe but it broke through the plastic years ago so I added a washer to keep it on the outside and it works just fine. Just a few days ago I cut up a cord of ironwood with it.
I'm sure a Stihl or most anything else is built a lot better and made for serious use, but for as little as you use the thing, what you got is probably fine. Just might need a little work. It's up to you.
I am also not totally sure about it being a rebadged Poulan. My first year cutting I got 3 Poulan 18" saws for $50 total. It didn't take long to burn the compression out of them. Yes a lot of the parts are interchangeable but the engine and everything seems to be better and stronger in the Craftsman. Even the body plastic is better. If anything the air filter is different and a lot better.
I think we just figured out how you burnt up those Poulans so quick.I have one of those same Craftsman saws that was given to me, 18" bar. I cut about 6 cord a year average. It has been a surprisingly very good saw. I leave the top cover off so I can run it hard and it doesn't get too hot. It has a full large air filter so no worries. I learned to keep the carb clean and adjusted so it runs strong. There is no massaging this one. I got rid of that sissy chain and put a real chain on it which made a huge difference. I hand sharpen it, keep it out of the dirt when I can, and I hate to say it but it actually cuts faster and stronger than my dad's small Stihl, also kept up well with another guy with a small Stihl. Yes I am in Stihl country too. Been cutting 7 years and no problems with kickback, I think it is more in paying attention to what you are doing. On a cold engine I either shoot it with starting fluid for instant start, or just pull 5 or 6 times and it starts. Warm engine starts right up and it runs till the tank is basically dry. Actually my only gripe is the gas cap, for some reason the threads have tightened up to where it takes channellocks to turn it. And the bar adjusting screw, not really a gripe but it broke through the plastic years ago so I added a washer to keep it on the outside and it works just fine. Just a few days ago I cut up a cord of ironwood with it.
346XP is what the 353 aspires to be when it grows up.
Go run that 026 your neighbor has, like it? Good, now get hunting for a used MS260(Pro). Should land in the $300 ballpark for a nice example. Or just bite the bullet and pick up a new MS261. Dust your hands off and declare the task "DONE!"
Yah, that.
x2
Currently I'm looking at a Redmax G5300 which is basically the same thing as the Husky 353 but I still have no idea which one I want to pull the trigger on. However a 346xp might be the perfect saw for my needs... still looking though. I just don't want to buy a saw made in China.
Well, I've read your posts here , so I'm going to make a recommendation . Go with a Stihl Farm Boss , or a Husqvarna Rancher in the 60cc range if You just want a reliable firewood saw that won't break the bank to buy , or own .
It would be nice to have a full handle on it so you could fell with EITHER side of the saw. But not enough to buy a new one.
Hmmm..... starting fluid in a 2-stroke....... along with running the gas tank dry... where is the smilie with the hammer hitting itself in the head?.
Full wrap handle on a MS250C......love it.
Something is definately wrong with your 390 if a 290 ran with it. With a light mod my 310 runs just behind my stock 361s. My 026/260s are all modified, and they do not keep pace with my 310, which has the power of a stock 390. ????
