what's wrong with a 125+ degree delta T on a boiler/water heater?from their site on the Gasifier specs:
(broken link removed)
?????? This must be a mistake..
- Rated Output:500,000+ BTU per Hour
- Unit Fittings:1” Copper Male Ends
Scott
Scott
I can only imagine the velocity of water that would be required to move a half million btu's through 1" pipe. I think I also read on that site that all of their boilers hold "10-15 gallons" of water. If I was really bored I'd love to briefly review the thermodynamics involved in transfering that much heat into into such a small amount of water.
just in case it didn't come across, that's sarcastic....what's wrong with a 125+ degree delta T on a boiler/water heater?
sounds like solid engineering to me
K
I think the idea of a masonry boiler is pretty good. Not sure about this one particularly, but the principle doesn't deserve the ridicule at all.
Agreed, but I thought this was an outdoor unit...so you are talking massive insulation.
I happen to like the masonry idea..but not outdoors.
I still do not see 1/2 million btu vs 1" outlet and limited capacity, as favorable..especially when the mass needs to be maintained.
On the flue comments again I concur and why not do a Finnish style masonry design with dual downturns to increase efficiency and absorption.
Scott
Aside from the fact that the Heiss is a different animal you are still wasting wood by burning it in it's unseasoned state Mr Beardsley. It costs lots of BTU's to evaporate the water out of your wood if you use the heat from your fire to do it.
Just so we aren't talking in code.....this is the unit he is referring to.
Thanks for this link. I don't know why, but I didn't see any links or pics of what this thread was about until you posted.
I welcome the discussion of this new-to-me gasser.
I trust the moderator to keep the sales pitch to a medium level, and let us chime in with our thoughts and experiences.
If the burning wood is drying out the green wood above it, the moisture is still making its way up the chimney.
You can't avoid the creosote, as far as I can see.
(There is no breakdown of the H2O in the 2000F gassification chamber, is there?)
by volume you can get the same btu storage or more out of masonry.
This is one of those things that one would assume to be self-evident, given that masonry is more dense than water, but it is incorrect by a large margin.
You have to go by the "specific heat" of the material, and water's specific heat is dramatically more than masonry (about a 5:1 ratio). Don't believe me? Ask the masonry industry:
(broken link removed to http://www.cmacn.org/energy/basics/mat_sh.htm)
I'm not trying to be snippy, but it _is_ essential to tie discussions and advocacy back to physics, not supposition.
Water's physical characteristics, specifically in regard to heat retention and heat-transfer, would be considered truly extraordinary in comparison to nearly all other materials (except for really exotic phase change materials), except we're all so used to having the stuff fall out of the sky that we don't stop to realize that it has these unique properties.
At risk of playing devil's advocate against myself, I _can_ envision situations in which a hybrid masonry heater/ boiler might make sense- such as when the masonry heater part of the unit is located in a rather large relatively open space/ spaces (so that it can spread its heat easily and directly by unrestricted radiation and convection) but you also want to be able to send heat to a different area that would not be effectively warmed directly by the masonry heater. Seems like you lose the stone-simple near-failproof characteristics of the masonry heater in the process though, without fully gaining the ability that a high efficiency boiler + well insulated water storage yields of bring able to efficiently"bank" large quantities of heat for release only when or at the rate that is desired. Different strokes for different folks.Exactly. If you're going to use water as the heat transfer medium, why not just heat it directly and install enough storage for the parameters of the job?
Water has a specific heat of 1 (one). You'd think you can't go lower than that, BUT, all other materials with the exception of phase change materials, ie, eutectic salts are lower in specific heat than water.This is one of those things that one would assume to be self-evident, given that masonry is more dense than water, but it is incorrect by a large margin.
