mike1234 said:I love my 290, has been great, never any problems caused by the saw (there was the one problem when I dropped a tree on it, but can't really blame the saw for that). For whatever reason, there are some 290 haters out there, who think everyone needs to know how bad a 290 is in their opinion. I cut with a guy that has 2 husky's of about the same cc as my 290 and 270, and his saws are not better than mine, maybe equal, although mine start easier than his.
Just because I am always looking to tinker, I am thinking of a muffler mod, but can't figure out how to do it for the 290 (most of the instructions I have seen for mods are for bigger saws).
aandabooks said:mike1234 said:I love my 290, has been great, never any problems caused by the saw (there was the one problem when I dropped a tree on it, but can't really blame the saw for that). For whatever reason, there are some 290 haters out there, who think everyone needs to know how bad a 290 is in their opinion. I cut with a guy that has 2 husky's of about the same cc as my 290 and 270, and his saws are not better than mine, maybe equal, although mine start easier than his.
The muffler mod is very simple. Pull off the muffler and in the recessed area above the slots drill 4 3/8" holes. Possible make the 2 slots into one slot with a die grinder or 1 hole between them. Wash out all of the metal debris from the drilling. Take the deflector shield and open it up. Direct the extra airflow in whatever direction you chose. I would advise against directing it towards plastic. Put the whole assembly back together.
Take the limiter tabs off of the H/L adjustment screws. Careful when you do this or you'll have to get new ones from the dealer. About a $1 each. Fire up the saw and set the L jet so it idles well but doesn't spin the chain. Richen (CCW) the H jet until you hear a 4 stroke blubber at WOT. Put the saw in some wood and you shouldn't hear the 4 stroke. There should now be a good snap when going from idle to WOT.
Oh yeah, don't forget the hearing protection because you just added probably another 10-15 decibles to the exhaust note of your saw.
mike1234 said:The Muffler part looks easy enough. But what are the limiter tabs? Do I just unscrew the adjustment screws all the way out and then do something. Just don't want to do anything there that could hurt the saw.
I presume you mean the Hi jet. A lean saw rev's too high with no load. I set it rich enough to run rough and it only smooths out when I put it under load.mike1234 said:Also, it is hard to know if I am running it too lean...
aandabooks said:Might need to open that deflector up just a bit more. That is basically what my muffler now looks like. I did put two holes on the other side of the deflector. Carb setting was about a 1/4 turn CCW past factory. Every saw is different. Once you get it dialed in, I think you're going to be happy with the results.
