Is there a difference is speed between a 24" cylinder, and a 30" cylinder assuming the ram and piston are the same size, and not counting the fact that the longer cylinder would of course take longer to travel because of the longer length?
I have a 30" cylinder now, and am considering installing a shorter 24" cylinder.
Just wondering if the power/pressure/speed changes with the length of the cylinder, as opposed to the bore diameter.
The splitter is set up to split pretty long pieces with roughly 28" of travel.
I'm splitting all my wood at 16".
Even short stroking, I'm wasting a lot of time going a few inches farther than I need to, as it is hard to judge just where to stop.
And then when I do, the control lever sticks and retracts all the way anyhow...
The long cylinder I've got has a minor leak at the seal.
I may be able to get a good used 24" cylinder pretty cheap.
Thanks
Rob
Thanks
Rob
