You do realize the splitter is not the problem here, right? Right?
I won't get out and use a splitter at anything below 40 degrees or so. Yes, that's a positive number; I simply do not need the firewood that bad.
At -25 degrees (regardless of C or F) I'm inside with not only the wood stove rocking it's life out, but I'll probably be sitting on it.
I'm glad there's people like you that can live in Siberia; I never have and never will.
Hi southeners
I i feel the same way about where you live.
Can't stand the heat in the summer.
Don't like the fact that you have to be aware of Ticks that can make you sick just from walking around .
Can't stand snakes,both the slithering kind and 2 legged
Don't think much of spiders that can kill you,especially since we are always withing 8 ft of a spider.
Don't really like the fact that your bodies of water contain species of reptiles that want to eat your a$$ or bite you and just kill you.
And even though your typical temp is warmer you still have to process wood to heat your home,plus a lot of you use as much wood as i do.
My shop hasn't been locked since i built it in 1984.
My car and truck parked outside have keys in them.Both my Kenworths parked at work have keys in them.My 950 loader and my 426 Cat Backhoe have keys in them.
I can go cut wood and not worry about where i am cutting,or if someone is going to take my cut wood.
That is just a few points that make the cold easy to take.It is very dry where we live so even -40 F or C isn't the end of the world.There isn't much you can't do if it is that cold,it just takes twice as long.
Unlike when it is hot all you can do is find shade and cool off.
So enjoy your little slice of hell.And i will do the same.
A happy camper in the cold.
