After complaining on this site all last year about a poor burn in my Jotul 3cb, I finally took the advice here of trying a different wood supplier. I did this year and the difference is remarkable. Much hotter and secondary burn which I could never get before. It is obviously better seasoned than the wood I had used in the past.
Which brings me to my next question. Now that I know my wood is properly seasoned, how important is it to keep it dry as I store it outside. If well-seasoned wood gets soaked with rain, how long does it take to dry to where it will burn efficiently again? Is it simply a matter of a couple days of winter sun and wind, or longer. Are the moisture contents of green wood comparable to moisture content of wet, well-seasoned wood or are these two different things that are not comparable?
HehHeh . . . sorry . . . couldn't help myself . . . I'll behave now. Now that I know my wood is properly seasoned, how important is it to keep it dry as I store it outside. Answer: It's not really all that important . . . if the wood is seasoned it will stay seasoned . . . that said . . . wet wood doesn't ignite all that easily . . . while it would dry out in a few days of sun . . . if you're starting to burn right about now I would recommend top covering the stacks of wood . . . it will allow wind and sun to continue to season the wood, but keep it dry from rain/snow/etc. If well-seasoned wood gets soaked with rain, how long does it take to dry to where it will burn efficiently again? A few hours to a few days . . . depends on the weather conditions (i.e. how windy or sunny it is outside.) Is it simply a matter of a couple days of winter sun and wind, or longer. Are the moisture contents of green wood comparable to moisture content of wet, well-seasoned wood or are these two different things that are not comparable? As another member mentioned . . . there is a difference between green wood (i.e. unseasoned, does not burn well) and seasoned wood that is wet (i.e. wet from rain or snow) . . . if given the choice of having green wood that is dry or seasoned wood that is wet from rain I would take the seasoned wood every single time.
