savageactor7 said:fyrwoodguy real nice grapple but I could lift those twigs with my johnson tool.
Backwoods Savage said:We have somewhere between 20 and 30 cords.
Your a.......SAVAGE
is that with a 5100 i hopeBigg_Redd said:Next years pile is in the woodshed and the year after is almost done. All free.
savageactor7 said:Just joking with ya fyrwoodguy I'll bet the helpers just love helping out...when their that age anything to so that has a motor is fun.
Chief Ryan said:Backwoods Savage said:We have somewhere between 20 and 30 cords.
Somewhere i read that you go through about 3 cord per year. 20 to 30 CordYour a.......SAVAGE
This is my first year burning a stove. I've used it 24/7 since November and at night through October. I think i'll only go through 3 cord myself most likely less. I have about 6 to 7 cord split and stacked ready for the next 2 years.
Backwoods Savage said:Chief Ryan said:Backwoods Savage said:We have somewhere between 20 and 30 cords.
Thanks Chief. I knocked down another big ash this morning. So the pile just keeps growing. Actually this is the first I've cut since that cold spell and today the temperature is up around 30 so I grabbed the saw and cut away.
Just looking right now it does look like we will go through a little over 3 cords this winter. But this is the type of winter when we burned 7 cords or more with a different stove. Man I love that Fireview.
Chief, that sounds great that you have 6-7 cords ready. Now you are a real wood burner!
relic said:I've gone through everything I had. I'm scrounging for more. Got two dead trees yesterday and it will keep me going for now.
Got tired of not being prepared and bought a splitter before Xmas. Only got to use it once. I am probably going to need a bigger chainsaw as well.
But next winter, my goal is to have two years set aside and that means about 20 - 24 cords.
iceman said:relic said:I've gone through everything I had. I'm scrounging for more. Got two dead trees yesterday and it will keep me going for now.
are you kidding????? what are you heating with that you need 10-12 coed a year?
relic said:Whatever I can get with the exceptions I mentioned earlier. My stove is inefficient and I burn it hot so I can turn on the fan in the furnace. I could have had a lot more wood, but didn't pick it up because there was already way too much in the yard unprocessed. I live in town. Our stove will take 28" wood.
Ken45 said:relic said:Whatever I can get with the exceptions I mentioned earlier. My stove is inefficient and I burn it hot so I can turn on the fan in the furnace. I could have had a lot more wood, but didn't pick it up because there was already way too much in the yard unprocessed. I live in town. Our stove will take 28" wood.
I have read that trying to move stove heat around with the furnace fan is quite inefficient due to duct leaks, heat loss, etc. My own experience agrees with that.
What I do find effective is to put a fan on the floor near the doorway (we use just the small 10-12" fans), blowing floor air OUT of the rooms that need heat. That pulls in the warmer air in without having to hang fans in the doorway itself. Even the small fans on low do a good job of moving cold air out and warm air into a room.
Ken
jackpine said:I realize everyone can not move the heat without mechanical assistance, but when I purchased my 1915 two-story brick "4 square" house several years ago I established a thermosiphon of air. First I lined the two flue chimney that served the first floor fireplace and forced air furnace in the basement. Poked a hole in the flue just above the fireplace, masoned in an attractive chimney thimble and installed a wood heater. Power vented the forced air furnace in the basement, rebuilt the thimble and installed a wood heater. Over a period of several weeks I scrounged several iron floor registers from razed victorian homes. The largest register was about 3 x 4 feet. I cut out the flooring above the wood heater in the basement and placed this register in the opening.
Then I installed the other registers in the upstairs rooms, placing them under each window. I wanted to install registers on the first floor, but my wife stopped me. "Let's see if this thermosiphon idea of yours works for the first and second floor before we cut openings into the basement." My better half was doubting my vast knowledge of physics. My theory was that the open stairwell to the second floor would act as a thermal chimney, warming the 2nd floor rooms. Cool or cold air from the windows would sink through the floor registers and be drawn to the stove on the first floor. This cool or cold air drawn and sinking through the registers would in turn draw warmer air from the upstairs central hallway into each room to complete my thermosiphon cycle. Suffice to say it does work and when the house guests ask about the cute antique registers in the room ceilings (or floors), the wife "expertly" explains the purpose and function.
Not satisfied to let this approval rating from my wife to go to waste, I expanded my work. As mentioned, heretofore, I have a wood heater in the basement with this large antique register directly above it. Without register openings into the basement, I wasn't sure if I could complete a thermosiphon cycle. By firing the basement stove with the register overhead opened fully, I could get heat into the first floor, up the stairwell to the second floor, but the question remained how to get the cold air back to the basement stove. Well I cut a hole in the basement door, installed a "modern" register, cut holes in the first and second floor boxed in laundry chute and installed "modern" registers in each opening.
If temperature does not drop below 25 degrees and the wind is not blowing, the basement stove will heat the entire house comfortably. Below 25 degrees the basement stove is not fired...the first floor stove is fired up and it will take care of the heating needs.
