ABMax24
What are everyone's thoughts on pulling the cap on the bottom of the cleanout tee to stop an overfire? Mine is extremely easy to access as the stove pipe goes up 4 feet from the stove 90's out the wall 3 feet to the cleanout tee then up 32 feet to the cap. If I seen an overfire I could be out the basement door and at the cap in under 20 seconds. My thinking is this would cool off the chimney allowing a huge inrush of cold air as well as significantly reduce the draft to the stove and cut the amount of air immensely. Obviously if there was a chimney fire with this it might be a bad idea to add more air to the situation.
