We bought a house with a wood stove and have decided to pull it out. The stove is in an alcove in the living room which extends out into the garage. The pipe goes up through the alcove roof, then through a portion of the garage attic, then up a chase on the outside of the house. The chase is rotten and will have to be taken out, but we are hoping to put that off until next year. The alcove ceiling is temporarily foam board as the wall board was rotten and falling down. The stove has some rust damage and the garage roof has some mold damage from water that has entered through that old chase.
The pipe is about 9.5 inches in diameter, so I think it's 8 inch double walled pipe. I need to get it disconnected and out (at least out of the living area) so I can fix the ceiling and take the stove out. I don't know how (or if) this is supported in the chase, as you can't see up there. There are no bands holding the pipe together, looks like is just held together with sheet metal screws. If it has to be taken apart from the top, I'm not sure how to do that without tearing the chase down to access it. Thought about sawing through it to see what happens, but not brave enough to do that without more info.
House was built around 1980, if that is of any importance. Over my head here and appreciate all suggestions!
![How to remove double wall pipe in an outdoor chase. How to remove double wall pipe in an outdoor chase.](https://www.hearth.com/talk/data/attachments/314/314323-c86987b852319e59883e0676700c6676.jpg)
![How to remove double wall pipe in an outdoor chase. How to remove double wall pipe in an outdoor chase.](https://www.hearth.com/talk/data/attachments/314/314321-58f7032390abb625433ff5d72a8cf659.jpg)
![How to remove double wall pipe in an outdoor chase. How to remove double wall pipe in an outdoor chase.](https://www.hearth.com/talk/data/attachments/314/314322-c0bb132fef934d65dbf5b8c898647ed7.jpg)
