You'd need a big peavey if you had to roll stuff like that around all the time. Nice one.
I broke the hook on it once and had to reinforce the weld, but works great now.
Have you gone and burned all the trees?
I know what you mean. There are no trees here in this part of Wyoming it is just grass land. I scrounge all my wood from town or go to the mountains.
You do realize that sooner or later some of the bucking you do on those logs is going to be cutting from the top down.
All you need is one plastic wedge and do not worry about pinching the bar.
I used a plastic wedge while bucking for the first time the other day. It's a pleasure. No staring at the kerf, just start the cut, bang in the wedge and finish. No worries, no kickback, no problems. Done it both ways and I'm liking the wedge.
Have it your way but as far as I'm concerned for $4 bucks the added safety and convenience when needed is worth it. Nobody said anything about absolutes or cutting w/ the saw in one hand and a beer in the other but the wedge does what it's supposed to.Don't even start believing that wedge will stop/prevent a kickback. I have started using them for felling but see no use for them for bucking. If I need to wedge a buck I am not looking at the log right.
+1000 to this. Any time you can make the log lighter, it will be a lot easier to roll over.Dig under that spot that has some light under it. Then make the first cut up through the log. Then you have two pieces that are a lot easier to flop over.
But first, I would cut from top down and keep a very close eye on the kerf. Any movement, you get that saw out fast. You can do this without pinching the saw if you pay close attention to it. Then go about the under cutting. It is simple and it works.
But your trees are nice and round.......his have large limbs sticking out. Those will be difficult to roll over, even with help.With the right peavey you can roll those logs. This is one I made just for large logs.
OP, you are correct.I really don't want to pinch the bar. I only have metal wedges and would hate to hit one with the chain.
In principle you are absolutely right. If done correctly, there is no need for wedges. But working by yourself, and especially new to working with wood this big, I HIGHLY recommend a felling wedge. You get your cut started and insert it so that the saw cannot be pinched.
Don't listen to him, he's still loopyDUH.![]()
