I am curious... can anyone tell me how many bags per day they use in the dead of winter? Each bag is 40 lbs correct? The prices I heard avg. $4-5 per bag depending on premium, hardwood, softwood etc.... is that correct?
"Please don’t say you are installing the stove in an unfinished basement and expect to heat up the foundation....please.....please....
You do understand that there are hundreds of tons of cold earth and cement at a constant 45 degrees (Maine)......and you are going to heat it up with a pound or two of pellets per hour?
Put the pellet stove in the living area or use a pellet furnace and tie into duct work. Otherwise, the cost will be HIGHER that the cost of oil.
You are correct in that BIGGEST savings often comes from conservation and other common sense cutbacks."
.... thank your pointing it out. I am aware of what you are saying and have considered it & realize I can't "heat the foundation". However it won't be radiating cold air (45 degrees into the house if the basement is heated) The floor plan in my home doesn't allow me to install in in the living area or I would LOVE to. I've got a 1900's Victorian. My livingroom is 15' x 15' and has 5
doors & 2 windows and zero exterior wall space to install...
![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
I have FHW Baseboard heat. The home previously had FHA but a previous owner took it out. The only remaining evidence of FHA is the floor vents in 1st floor of the home. The only option I have is installing in basement and allowing heat to rise through the vents in the floor.
