How dry I am
cg711
19
southern ct
I have heard that heating with wood will dry the air in the house to the point of discomfort ( scratchy throat - bloody nose etc ). Anyone experience problems or have solutions. Is a kettle of water on or near stove sufficient to replace moisture in house?
Thanks CG711
First time wood burner with new Regency I3100 insert
I use a water kettle on the stove and a good humidifier set on high all day long... A must have! :-)
Thanks CG711
The dry air - bloody nose/itchy skin is definitiely true. A humidifier or pot of water on top of the stove will help alleviate this problem. My skin gets very itchy and my daughter's nose bleeds frequently during the winter months. I am installing an outside air kit for my new stove and will try a humidifier if ithe air needs additional humidity
Not everybody has the problem to that extent, but it can happen. The outdoor air kit will certainly help as will water on the stove. A humidifier is probably the best solution but we only put water in a big pot on the stove. Still gets dry but not so dry that the skin gets irritated. Nothing says you can't put two kettles of water on the stove either. We even cook on the stove which adds to the moisture, but you must pay attention lest the food get dried out quickly. Just part of the learning curve.
I ahve a whole house humidifier in the same room as the stove. Definatly makes a difference!
