Have you ever gotten the stt up to about 700 for a few minutes to clean off the glass? Usually works for me. Also…I know it’s another expense, but the cat REALLY has made a huge difference in the operation of this stove. The glass does stay clean…er and the temperature has been way easier to control and once it lights off there is no smoke coming from the chimney. Here are some pics…stove’s been running for about 24 hours now.
View attachment 300270 View attachment 300271 View attachment 300272
I see you figured out what that front shelf is for on this stove
I think Im going to get a little car vac. I have a little brush/dust pan as well that works but I end up spreading fine ashes over the hearthstone floor etc.
No I havent gotten to 700 STT. Id be fairly panicked if I did honestly as the book says not to get above 650 (too often for too long). Whatever that means right? The most I've done was 650. The other day, I was positive I hit a new temp as I was in the living room and told me wife "do you smell that". Yes...it's the cast iron/painty smell that for the most part has burned off for us. So I rushed out to see as I had just loaded the stove up about 20 mins earlier. Nope, it was at about 550 only. The only thing I can think of is, I left the damper open and air control on high to 'catch' the new logs I put in there. I meant to do that for only about 5 minutes but lost track of time. So maybe the flames were reaching areas they had not before. Or flames were reaching up the stove pipe higher than they were before as it is apparently with the strong draft when I open the top hatch, I can see flames going up through the damper and into the stove pipe like a jet engine!
My glass is still pretty dirty. I havent cleaned it intentionally to see what it will look like burning only on weekends in a couple of months. Ive had it completely sooted, but now it doesnt seem to soot up as easily. Id say it is about 1/2 the way clearer whereas I can easily see through it. 1/4 is sparely see through whereas another 1/4 is covered in thick black soot. The stove is interesting to control. And yes Im sure temps outside will change how I operate the stove in the coming months. Last weekend I loaded the stove to the top and shut down the air control to the 2nd lowest setting. I woke up the next day to 1/2 of the wood still remaining and STT at 350. The room was about 72, but it was only about 50 degrees overnight. This weekend, I loaded it up and woke up to only some small coals. Nothing that could start another fire so I had to add some kindling, start that then add my splits. I set the control to I think the 5th click. It was about 42 overnight. I tried again the next day and went to the 4th click and that seemed to be the sweet spot whereas I had some larger coals in the morning and 41 overnight.
I had a head scratcher once this weekend. I had what was left of two-three logs burning on about medium but the stove was rising to temps that were making the room uncomfortable (75 degrees) so I lowered the stove abit but it kept climbing. I then shut it down all the way but the stt kept climbing. The two-three logs that were left from a full load were glowing red hot. The air was mighty that evening, and colder. I was starting to get concerned that it was going to get close to overheating, and thought what would it do if it had more wood in it! Well then, I just simply added alot more wood on top of this leaving everything shut down, and within an hour the STT dropped to 350 degrees. So I cranked it to full open for awhile then back to medium, and I saw some nice flames and the STT went back to about 500 and stayed there.
I find the best flames, best more even heat is running this stove at medium. Once the wood burns down to most of the contents being red hot, either let it ride and it will run hotter or load it up. I like to see the flames, so keep it 1/3 of the way full on medium seems to be the sweet spot for me so far. Or about 1/2 filled. If I load the stove up with big pieces to the top and want a long burn, I cant forget about seeing flames.
I also learned this weekend, that putting the thermometer on the griddle plate early burn (after you start it and for some time after) is rather misleading and inaccurate. Sure the griddle may be 600, but the rest of the stove (sides for example) is NOWHERE near up to temperature. That griddle heats up and cools down MUCH faster than the rest of the stove. So I put the STT thermometer behind the griddle until I've had it running for awhile, say 2-3 hours, then move it back to the griddle. At that point, the temperatures match, but prior to that, you cant really trust that griddle temp.
