At first I thought you said your kids looked like big balls of chocolate :wow: Now I get it! If they ate one of those it would probably put them off of chocolate for quite a while!Highbeam said:I am unfortuante in that I moved from a deep firebox stove to a shallow one. I can no longer lay two spits side by side and build the fire in the middle since the air intakes will be blowing against the side of a log and not on the fire. North to south stoves are easier to start IMO. I had been a religious paper baller for my whole burning life. It's what my dad did and he taught me. It works fine and will always work but you have to find newspaper and you have to scrunch it up every day.
My latest discovery, courtesy of this group, is the supermarket wax log. I bought the jumbo one for 1.50$ at Albertsons this weekend and opened it up. I used my hatchet to carve off a chunk about the size of a cookie ball. You can squeeze the chunk into a ball and it will hold. You can quickly make a pile-o-balls. I set the cookie on my gravel driveway and easily lit it with a regular lighter. It took off and burned with about a 6" flame for a good 15 minutes with no smoke. I have lit two fires now in my stove with the wax cookie instead of paper. Much quicker. I set it right on the ash bed and stack kindling criss cross above it and then small splits criss cross above that to the roof of the firebox. Easy peasy. I just need to watch the kids since they look like big balls of chocolate.
