Disagree.
It sounds like you may have too big of a stove and trying to run it too cold to maintain a proper fire (the Legend is almost 3X the size of the VZ Defender) its gonna be the same with any tube stove...you may want to look at cat stoves...
Not initially. But when all the stuff they suggest, I need to spend more money, do this, try that, and nothing works, well try this. I get fed up up with people that call themselves professionals and look like More Ons.
Disagree.
Disagree.
People say "you can make a small fire in a big stove, but you can't make a big fire in a small stove"...while true, the big stove still doesn't burn that well with a small fire in it, unless maybe its just a small load of wood, and then its left to burn wide open...and a larger load of wood wants to be burnt hot in a tube stove, that's just how they work.
My FIL is an old school wood burner...they had me put an Englander NC30 (same size as your Legend) stove in their new house...WAY too big, and so he just runs small loads at a low rate in it...always a creosote mess...I've mentioned proper techniques many times, but he is an old dog, and that's a new trick...so he runs it like his old stoves...a stick or two at a time, and either wide open, or way too low/smoldering. I've given up and just clean the chimney for them...and he cleans the door glass...often!
SOAPSTONE AND CAST IRON—A BEAUTIFUL PAIR The Fireview wood stove is styled after the famous soapstone wood stoves made in Francestown, New Hampshire during the 1860’s. The ornamental ironwork on the Fireview wood stove reflects the classic architectural style of the mid-nineteenth ce
