Don't be confused with "efficiency" claims by dealers or Mfgs. This term is widely misunderstood and a bit complicated.
The amount of the heat that is actually transferred into the room from your stove depends on a number of factors:
1. Combustion efficiency. In all new Phase II stoves this percentage is near 90% with dry cordwood.
2. Heat transfer efficiency (thermal efficiency). How much of the heat generated in the firebox escapes through the chimney into the atmosphere (stack loss) depends on the firing strategy and the thermal mass of the heater. Newer metal stoves and fireplace inserts with firebrick lining are designed to be clean burning but still have poor thermal efficiency because they lack a thermal mass that functions as a heat exchanger. The combustion efficiency multiplied by the heat transfer efficiency, is the overall efficiency, but this term still does not fully characterize the true efficiency of a heater.
3. Linearity of output. For clean combustion, wood requires a brisk, hot fire which results in short burn times. If the heater has no storage capacity the fire must be damped, otherwise all the heat is transferred into the room during the burn time. As a result, the room becomes overheated and/or the stove over fired while the fire is burning and under heated after the fire has died down. An overheated room loses more heat to the environment because of the higher temperature differential between the room air and the outdoor air.
4. Partial charge efficiency. See above post.
So, there's more to it than "burn efficiency". If you can digest the above, you'll be ahead of the pack.
Aye,
Marty
Aye,
Marty
