deck2 said:You guys are really trying to squeeze every possible BTU out of your wood, I just decided to replace our old water heater with a On Demand unit. Costs a little more at first but was told it would last twice as long and use a fraction of the gas.
kd460 said:The use of a compressor tank is not a good idea either, unless you like rusty water. The tank is not coated on the inside like a hot water heater. KD
LEES WOOD-CO said:kd460 said:The use of a compressor tank is not a good idea either, unless you like rusty water. The tank is not coated on the inside like a hot water heater. KD
Neither are well casings or bladder tanks.Don't see any rust in my water now .
Adios Pantalones said:VTZJ said:Adios Pantalones said:I'd also add that heating hot water is an inefficient way to recover heat.
Anyone know how long it takes to freeze ice?
If you are having trouble freezing your ice, try unthawing it first.
Unthawing is just freezing... How long does that take for ice?
Adios Pantalones said:""How long to freeze ice" is like "where do they bury the survivors". Ice is already frozen and survivors don't get planted."
umm- that was the joke... look at the earlier posts
d.n.f. said:Well it is not funny anymore.
Good point. Another great reason to never use hot water to cook or drink. I have seen recommendations to set it at 120. That's where we set ours and we don't need to add cold water when showering. I would say try it if you can keep the cost down and let us know the results.Jimbob said:I think that should work okay. Just note that sometimes when water is stored at ~ 100 F or so, bacteria can grow in the water causing a rotten smell. Clorinated city water is far less prone to this than well water. This is why the recomended min temp setting on a water heater is 140 F.
