I have the high temp silicone tape in black. Would that really work and take that kind of heat right off the stove like that? Ive seen mentioned on here before by others about using to wrap joints but never right there where venting starts. Just curious because that would make it a lot easier to take off if ever need be.My opinion ONLY.
If you ever plan on taking that joint apart, I would use the clear silicone tape.
It is self sealing, and you can take it off easily. Available at HD..
Good luck taking it apart if you silicone the joint...
Dan
What in earth is Milpac?
Guys he just asked what is a good black hi-temp silicon
Milpac and screws is just as safe and is easily removableYou should be putting an appliance adapter that would then connect to your T....I’ve siliconed the appliance adapter onto the tailpipe of the stoves I’ve done...pretty sure it’s safer too
Is this high temperature?Henry (McManus fuels) forwarded your email to me..
This is what I would use... if I was concerned about that...
@Home Depot.
Dan
Not without an appliance adapter. That is absolutely requiredI didnt get the appliance adapter just the 3 inch Tee to 4 inch vent. Maybe this milpac should be an option?
Then should i return the piece i got and get the 3 inch to 4 inch appliance adaptor and the get the 4 in Tee with clean out?Not without an appliance adapter. That is absolutely required
I don't know anything about the setup so I really can't advise on layout of the venting system. But an appliance adapter is nessecaryThen should i return the piece i got and get the 3 inch to 4 inch appliance adaptor and the get the 4 in Tee with clean out?
High temp non-adhesive sealant. I use it on any nongasketed joint in a pellet vent system that may need to be disassembled.
You can thank the old guy I learned from for that one.WOW, that beats red RTV hands down for elasticity and maximum temperature I just ordered a tube for my own use and will give it a try on my outside venting when I reassemble it in the fall.
Thank you young man....![]()
Then, thank you dad...................The old guy is my father btw
