rsnider said:how much insulated pipe is needed or recommended for these boilers? how many feet? just wondering if it was to sit in a shed outside. if anything just give me a guess.
muleman51 said:these boilers blow my mind. you litteraly have to be a rocket scientist too operate one. I have not slept a good night since I installedmine 3 months ago. It has never worked right. At least when I had my old Aquatherm allyou had to do was keep it full of wood. It could burn 18 hoursor longer if you filled it full. Thought i might get some effiency out of my Adobe only headaches and still burns as much wood. Put up new chimney still doesnot work now have to tear it apartto see if its clean in back. wouldn't be a bad job if they had made a decent access panel that was removable. I can just imagine the shape of that tin by the time you get it off. Should have listened to my brotherinlaw. He has a Garn no problems, no chimney, no additional water storage, burn a fire once or twice a day and he can sleep being sure it will be ok in the morning. I'll bet he has less in his than I will have in mine by the time I add everything to make this piece of---- work. If you think I'm frustrated I am. Thanks for listening.
! Instead they sell you a boiler say good luck I never want to hear from you again and you are left to spend thousands to try try to make a bigger mess out of what you already have. there is another thread started under Adobe problems owner unite , started yesterday.ISeeDeadBTUs said:A little clarification here please . . .docgogo said:5) unit was up to 180-185 for 4-5 hrs. at that temp. not sure about the water temps but they would go from 180-185 to 105 or so. damper would be open .
IF you're saying you got the GW up to temp with a load, then for 4-5 hours it cycled on and off normally, then the damper opened and the water dropped to 105 . . .Then I'd say the GW is working the way it is supposed to, we just need to figure out why it ran out of fuel in 5 hours.
ON THE OTHER HAND IF you're saying you got the GW up to temp, the damper closed, then did not open until 5 hours later, whereupon it could not get up to temp . . .Let us know if this is the case, 'cause we need to ask more questions (first of which will be, Have you figured out the draft situation yet?) before I can say what is probably happening.
muleman51 said:If you have to put up 18' of insulated pipe, add water storage, cross your fingers, have the wind at your back. something is wrong with this picture . This industry needs to look at itself and come up with something that works or at least be very honest and tell a person exactly what all of the variables are and what they will cost up front or the systems simply will not work! Instead they sell you a boiler say good luck I never want to hear from you again and you are left to spend thousands to try try to make a bigger mess out of what you already have. there is another thread started under Adobe problems owner unite , started yesterday.
docgogo said:Anthony i took my chimney apart today to find approximately 3" of soot took about 10 min to clean out.
also the connection you saw is not homemade i have metal bestos double wall pipe with a mb connection to the single wall pipe.
checked all my joints today all were fine. thanks doc .
docgogo said:yes i have but i'm having mixed results
aquastat 190 with 15 deg dif.
up to temp at 6:00 eve.
cycles on and off correctly
11:00 pm two large pieces of white oak (supposed to be seasoned 5 months have not measured mc) temps at 180 deg.
4:00 am temps at 150 deg. wood red hot but temps down.
That's a 9 1/2 hour burn. I shoot for sustainable fires of 8 hours with effective heating capacity. What was the outside temp that day? How full are you filling the box? Am I missing something, because I though you were saying the wood was just sitting in the box not producing heat. Has that changed now to the point where the wood burns fine, just not as long as you had hoped?docgogo said:placed small split wood temp gets up to 180 within 1 hr.
6:45 am temp at 180 deg. filled with large pieces of white oak
home at 4:15 temps at 85 deg.almost know wood left burning.
