Last night around 12:30 I suddenly woke from a strange dream. I noticed my wife was restless & talking in her sleep so I woke her up. She started spasing out saying
"Something wrong, somthings wrong, I smell smoke, do you smell that!" I tried to calm her down but she was relentless. I couldn't really smell anything but told her I'd go check the fire.
What I found scared me big time. The stove was very hot, full of lazy blue flames, & smoke then all at once it ignited & went WOOB The top opened for a second & it blew out a bunch of smoke & some sparks. Then the cycle started all over again & it happened again. The air was fully closed & the bypass damper was closed. So I opened the bypass damper but then the stove quickly got VERY hot as did the flue piping. The fire inside the stove was a raging infero now. I closed the bypass damper but opened the air adjustment. This helped some but the stove was still blazing out of control getting hotter by the second. I put some new wood in but that made little to no difference. When I closed back the air it still stayed very hot & did the "backdraft" thing. Now I was a little worried. How do I stop this thing,..it's like a run away locomotive!! So I went outside & grabbed some good heavy wood that had been getting rained on for two days & loaded that in on top. Finally it started to calm down. I was able to slowly close back the sir with out it exploding.
So what the heck is going on with this thing??
The only thing I changed is I have been burning the last of my wood which is a lot of popular that I got for free. Do you think that could be the problem?
Also can anyone explain how the primary & secondary air works in the newer Vermont Castings Defients?
