I am finishing the interior of a small Vermont barn, insulating and drywall, with two floors of about 500 sq feet each (27’ by 19’) and we plan to heat it with a wood stove only. Each floor will be one large room, and each floor has two windows.
We plan to put the stove in the center of the first floor’s long wall, between two windows. The chimney will go straight up through the second floor and out the roof.
There will be an open staircase and we plan heating grates above the stove to assist with the hot air flow to the second floor. The walls and insulation will be new so it should be pretty tight, but it will be in Vermont where it can be very cold in the winter.
The stove will be the only heat in the building, so we need to keep it burning overnight.
I like traditional looking stoves like the Morso 2b Classic, or the Jøtul F 118 CB Black Bear, but I think they have short burn times. The Morso firebox is only .9 cubic feet.
I like the Vermont Castings Resolute Acclaim, which is rated at 1600 sq feet and a 9 hour burn time (1.7 cubic feet fire box) but I’m afraid that may be too much stove for the space. I’d like a cast iron stove.
Or should I look at a bigger stove with a bigger firebox and longer burn times? And will the heating grates above the stove get enough heat to the second floor? Any thoughts?
Thanks for your help.
