edge-of-the-woods
That's why we usually recommend to new members to dry their own wood. When it has been sitting for 2 to 3 years split and stacked in a sunny and windy spot, raised from the ground and top-covered it is almost surely below 20%. Testing a few pieces is then often enough to tell how dry the rest is.
The wood you got may have been sitting in a big heap somewhere with the outer pieces now being dry while anything inside still wet. Maybe get a helper and start splitting everything again. Have him/her measure the moisture content and throw the wood in piles of below and above 20% moisture. Then re-stack for the next winter what needs to dry further. Supplement the dry wood with compressed wood logs like Envi-blocks or Bio Bricks. Pallets are also an option: Often free and dry but a PITA to cut up and avoid painted to chemically treated ones.
This is exactly what I had to do last year. You might have to give up on that wood for this year, and burn bio-bricks or something like that.
Every stove should come with a brochure on how to season wood and identify moisture content.
Thank you
