Like said, don't worry about the glass, wood can rest against it no problem. I never worry about flue temp either, if the air is closed down, the flue should not get too hot... Load it FULL is key to making heat.I still feel like I'm getting wood to close to the glass? I did get it up to 500? But the flu thermo was scaring me! Just feel like its all going four the chimney? I wish there was something to keep the wood from getting to close to the glass for side loads....then load it FULL!
WOWI'm doing g something wrong then? My wood is all hardwood and seasoned 2 years. I guess you would call it a cold start as the thermometer is down. Top is warm to touch though? It is taking forever to get it hot! I'll try again when I get the kids to school. I filled it to my liking at 11pm last night. When it got up to 400 I shut the flu to 1/4 and went to bed. Got up at 8 and the eco fan wasn't even turning...below 100?
Are you measuring the temperature on the stove top or on the stove pipe?, you mentioned double wall pipe which would read much lower than the stove top.At noon it was wide open on the flu and temps were 350? Stove pipe temp with double wall uninsulated over that? ( I know I can't be accurate). Now its 1 pm and I had shut it to half at 12:30 and.....its dropping below 400. Never got above 450. And the woods almost gone,.down to almost coals. In less than 2 hours? It is really windy...but if I close the flu all the way the fire will go out? Can get this dang thing over 500? If I leave the flu wide open....how can the stove heat up? The pipe almost glows! This wood is GOOD I promise. I cut my own wood also. Usually 2 years in advance! Dangit
Yes the cold Oslo does take a 3 reloads and a full box of seasoned burning wood before the cast iron gets up to temp. Compared to steel box stoves I've run, the Oslo is the tortoise in a race for instant heat from a cold start. I guess it all those side wall burn plates, and mine with the cast iron top burn plates. I use a temp gauge in the top back right and recommended. After 13 years of having this stove I got a IR gun, not because I needed it, just for fun. Amazing how different the temperatures are as you bring it up. My single wall just above the stove will be at 400 and the top hasn't hit 200 yet. I think, Jakes start up temps could be internal flue just above the stove. They get the hottest first.OK...I'll stop worrying about the glass. But it dang near takes a load of wood to get this thing up to 400 from cold. My start. Rake coals and leave door open. Good bed of coals! Throw on some sassafras kindling front to back then load the stove with splits through side door. This keeps the splits off of the coals so the air gets under them? Then leave side door cracked till I hear it roaring. I may be to worried about the roar as I don't want to burn this thing up! Never seen my stove 600 yet? May be me worrying?
Thanks for all the replies. Seems as though I'm just not home enough to keep this dang thing full enough for it to do its job?
I have a new Jotul olso. My deal is....I can't get the dang thing to burn over 400 f for more than 3 hours?
Been following this thread cuz I cant believe you cant get heat outta an Oslo. I think you are not pushing the stove hard enough to get any heat. I've had the fire box on mine rolling with flames that you could forge horse shoes in it so many times it aint funny. Unless you get that stove super hot you aint gonna destroy it. I'm no expert on wood burning stoves except for mine and my set up. Take the advice you get and play with it for a year or maybe even 2. You gotta remember that what works for 1 guy may or may not work for you. Burning wood aint like a cookie cutter kinda thing due to so many variables. That being said, I have found with mine living in the middle of corn country flat lands, where wind is King and to much draft up the chimney, I have much better luck with smaller hotter loads of wood rather than trying to scrimp on wood consumption. I like to see my flu temps climb on a cold start and then shut the side door and the stove top temps start climbing almost right now. Mine is in the 24x48 basement and I can get the temps from 60° to 70° in less than an hour. Once I get the basement warmed up the heat radiates up to the upstairs with no fans or nothing. Oh, and that 8 hour burn time that you and I might have fell for as a selling point? Well, just sayin.Thanks for all the replies. Seems as though I'm just not home enough to keep this dang thing full enough for it to do its job? I'll keep playing with it. Man it scares the crap out of me when the flames are roaring in that expensive sucker!
