Ok this will be a long post, but any advise would be greatly appriciated.
I am building a new house with a detached shop this summer.
I am in Northern Alberta where it gets really cold often. Usually Oct - may is below 0 celcius. We often go a week with -25 C. Right not it's actually -39 C. We've been having daytime highes of - 25 and night time lows of -35 for a week straight.
Since our house will be new, we must have triple pain windows, 6 inch walls, styrofoam block basement etc.
The house is 1600 sqft on top with a 1600 sqft walk out basement. The shop will be 30 x 30 feet with 12 ft ceiling.
So I want to go with a outdoor boiler. I know several people with them, but theirs are older models.
I have been cutting and splitting 8 cords a year for 10 years for my current wood stove. I have access to unlimited spruce, poplar and some pine.
1) Do I go with a standard model or a gassification model? I know these need to run dry wood to be used correctly, but my worry is that I can't stuff the stuff at 7 am and go to work until 5 pm and have it still heat the house and shop. I thought I could buy a bigger model than I need to get a bigger fire box, than a dealer told me not to do this because in order to get the gassification process to function the stove needs to burn hot and I would end up wasting a lot of heat/wood out the chimney because the house won't need all that heat. So if I get the correct sized model, can I expect to fill the stove every 12 hours, or does it need to be filled more often?
I know with the old outdoor boilers you could stuff them every 12 hours and they kept the house/shop warm in -40 no problem.
My other concerns with gassification models is that I Will have to split the wood. Again the beauty of the traditional stoves to me is cutting 8 inch diameter logs at 36 inches long and shoving them in a stove without being split. Can I still do this with a gassification stove? I honestly don't want to have to split wood with a ODB. If I have to if I get a gassification stove, I will go traditional route.
2) I see some stoves can be dual fuel. I would love to have the stove set up to run off propane if the stove dies out. Can all ODB be converted to also run propane?
If a stove is set up to run Propane as well, does this mean I can get away without a secondary furnace in the home?
3) The original plan was to have a propane back up furnace in the house. My understanding of how to set the outdoor furnace up would be:
-have a heat exchange in the propane stove. Have the hot line from the ODB go to this exchanger where the blower will provide forced air heat upstairs.
-we will run in floor heating in the basement. The boiler would have a line going to the infloor heating.
-I will have a line going to the shop where I will have another heat exchanger with forced air.
Is this the correct way to set this house up?
4) How does the infloor heating work with the ODB?
-Do I need a tank inside the house or can the ODB line juse go direct into the floor lines?
- How do I control the heat in the in floor heating? What type of system/thermostat controls this? Is it in the ODB or in the house?
- is the infloor heating with a ODB set up the same way as tradional infloor heating withut a ODB except its just the hot line running into the system instead of a hot water heater providing the heat for the floor lines?
5) I don't have a ODB installer near me. So my plan was to have the local plumber set everything up in the house and then have a ODB installer come on site to do the exterior aspects and install the stove itself.
You might think I should just have the ODB come up to do the infloor, heat exchangers etc.. Problem is, the closest installer is 3 hours away. I cant imagine the bill he would give me to drive up for a couples hours of work here and there because he can only do so much as the house is being built.
EDIT:
I think I've narrowed down my choices of ODB to
Portage and Main
Woodmaster
Any thoughts? I narrowed it down to these two just because there is dealers in ALberta. There are other dealers for Polar and Central boilers, but I seem to find lots of bad reviews on them.
SHould I consider other makers?
EDIT:
Portage and Main
Woodmaster
