Hi all,
New here and I’ve done a bunch of research but need additional help. Forgive me for the length of the post.
Recently, my pellet stove from 2016 had issues starting up. I’d clean/vacuum the baffles but it got progressively worse. I chalked it up to a dirty chimney since I hadn’t cleaned it since last season. I cleaned it out(wasn’t too bad) but still had issues starting up/getting the auger going. Sometimes banging the hopper lid helped.
From searching, the most common problems were door seals(mine new in 2020) or a one of the switched. I jumped the vacuum switch and sure enough, the auger started dropping pellets. I ordered a replacement vacuum switch, was sent the wrong one. When I went back to install the old vacuum switch, I forgot to cut the power and when I was mounting it to the bracket, it caused an arc
. I know stupidity just potentially caused me more problems.
So now, I can’t get the auger to feed even when jumped. I wound up jumping the 3 snap switches, the lid and vacuum switch. I have power on the exhaust motor at startup, the control board fuse is in tact, the blue led on the board flashes twice for a few min on startup like it should. Everything appears to work. The convection motor works when I jumped the wire. I pulled the auger motor and connected directly to an outlet. It still gets power and turns but when I connected it to the stove, it doesn’t work, even when I left the auger unbolted to rule out pellets causing a bind.
Any thoughts on what it could be? My last resort would be control board. Just got two tons of pellets so I really don’t have the money right now for a new control board unit.
Also would like to mention that ignitor is glowing red on startup and I cleaned the thermocouple cover.
