moey
My opinion is that running a variable speed blower is doing nothing more then compensating for a system that was oversized. Its a delicate balance because often the heating load is more then the cooling load. So when summer rolls around your left with humidity problems you try and solve by running a blower all the time. People expect their air conditioners to respond immediately when the thermostat has not budged in three hours they think its broke. Put in to big of system and your faced with a battle of trying to control humidity levels by modulating a blower with the compressor cycling all the time. That is a advantage of a multi stage system your A/C can run on the first stage only and control humidity using one stage only.
HVAC installers put in huge systems because they dont want callbacks. Before our heat pump was installed our window A/Cs amounted to about 12000btu for 2000 sq/ft. They could keep up on a 90F day it was very comfortable in the house. Now we have about 2 tons stage 1 ( 24000 btu ) its not as comfortable ( much quieter though ). Unfortunately a smaller system would not have worked as well in the summer. Every company that came out tried to sell me a larger system. I finally found one that said Id be more comfortable with a smaller system but would pay a little more to operate.
Make sure whomever came out did a detailed heat loss calculation on your house. If they did not show them the door. Its not ok to size based on what was in your house previously.
