Heat n glo NorthStar
DAKSY
Patriot Guard Rider Moderator
Staff member
Yep. Been about 10 years, but I installed a bunch of em. I burned one regularly after I moved to sales.
It was the main source of heat for the store.
Great heaters, & the secondaries will keep you entertained for hours. Make sure you build your chase 6
feet wide if you bump it out from the house, so you can leave room for the mandatory Outside Air Kit (OAK).
Anything else you wanna know, just ask.
Reactions: Wlucas617
jetsam
4,224
Long Island, NY
youtu.be
This manufacturer has products they refer to as stoves, and products they refer to as fireplaces.
This Northstar unit has a metal body with a firebox, airtight doors, a regulated air supply, reburn tubes, and a top baffle. What makes it a fireplace as opposed to a flush tube stove?
I think of a 'fireplace' as a setup lacking airtight doors and/or effective air control, often with no firebox of its own.
DAKSY
Staff member
The Northstar is an EPA-Rated fire place. It is as efficient as a woodstove, but it looks like a fireplace.
It is Zero-Clearance as well, & is meant to be installed directly on a subfloor & within 1/2" of combustible
framing members, except for the front of the unit above the doors.
begreen
Mooderator
Staff member
Nov 18, 2005
78,572
South Puget Sound, WA
Heat 'n Glo makes gas, wood burning and electric fireplaces, gas fireplace inserts and gas stoves.
begreen
Mooderator
Staff member
Nov 18, 2005
78,572
No, a fireplace is a fireplace. They are built in as opposed to freestanding. You can move a stove out when you sell the house, not so with a zc fireplace. EPA fireplaces have doors and a secondary burn system (cat or non-cat). A stove is typically a freestanding unit, though fireplace inserts are sometimes called stoves.
Reactions: jetsam
mminor
141
Long Island NY
