Id collect about 10 and have 5-6 10 cord log trucks delivered.
Cut in 36” pieces and feed the dragon over and over.
I know a guy that has a Central Boiler of some sort.Face Cord or Full Cord? Either way 70 is a crazy # !
Was thinking about you during that 2 week stretch we had where it stayed well below 0 degrees F - could not believe how much wood I was burning through. Had me thinking pellet boiler for a house we are considering about in VT.Id collect about 10 and have 5-6 10 cord log trucks delivered.
The pellet option on my boiler is pretty nice.Was thinking about you during that 2 week stretch we had where it stayed well below 0 degrees F - could not believe how much wood I was burning through. Had me thinking pellet boiler for a house we are considering about in VT.
Interesting, for some reason I thought you used Wood in the shoulder seasons and pellet in the real winter portion. As I am considering a 2nd home having a pellet backup at both locations seems to be worth exploring. Any chance I can ask you for some pictures of what the Effecta looks like with the pellet system in place? Feel free to email me those at your convenience so we are not boring everyone.T
I travel once in a while and it makes it easy for the wife and kids; ran two weeks solid on pellets once.
They just had to add to the half ton hopper.
If I was looking at another place I would still go pellet / wood combo like I have now. I like the option to do either.
Just my 2 cents
My new install seems to be taking shape; I will have a underground run to one building that is 45’. Im thinking of running a supply-retrun diferential pump on it- instead of a pump running constant.
What temp do you keep your house at Maple?Sounds like about the same size as my house - which is 2700 sq.ft. in two stories, plus another 1500 in the basement (unfinished & not directly heated), 'typical' 20 year old construction. I burn between 5 & 6 cords. Going all summer would be maybe another cord. I think my boiler is rated around 80%. Not sure they can be directly compared though, likely some apples & oranges stuff going on.
I owned a CB 7260 for about 7 years in the Interior of Alaska.
4 buildings- over 11,000 sq ft
Pumps run 24/7
One run was 150’ underground with another 120’ inside building
70 cord per year
Sold it and ran as quick as possible
I compare the stack output of that old unit and my Effecta gasser- no comparison
The OwB is obviously a non efficient device
Therma-pex from Central boiler- buried 4 1/2 - 5’ deep. Frost line reaches anout 3’ here.Did you have good underground lines? (The ground stayed frozen over them all winter? )
That kind of wood burn is crazy!
Heating 4 buildings over 11000 sq feet had a bunch to do with it
Nice- no engineer here - Thanks for the confirmation. I just gain experience and wisdom through applicationSounds like a lot, but the numbers do check out. I’d expect 400M-500M BTU to heat that space, in our 5000 HDD climate, so almost triple that in your 14k HDD climate. That’s 42-63 cords, depending on species, at 100% efficiency. Scale for boiler efficiency and line loss, and 70 cords sounds just about right.
