Oldbarn70
Hi. A few things you can do right away: one is get a temp gauge like you said, but place it on the pipe close to the stove if you can because the top of the Manchester actually has a convection air space under it, so it won't be accurate. Talk to your local stove shop about what temp it should be (I like to get my base pipe between at least 450-600 before I slow the burn). That stove is big, so if you don't get it going hot, it won't work efficiently (like any stove), plus it will help burn out and clean any creosote build up. Two- take a look at your wood. If there are little hissing bubbles of water coming out the ends for more than a minute or so, your wood is not fully dry. Oak will do this often even if it's over 1 year split, that's why I burn mostly maple, beech, ash. I also put a damper on my pipe 6" from the stove which I turn to 45 degrees after I turn the damper way down to get a long burn. Make sure your horizontal section of pipe has a slight rise up, it will make a much better draft.
Make sure you don't have any open dampened fireplaces, etc. a few spots with cold air coming (some sketchy building going on in the 70's and 80's) can go a long way to negate a good heater.
I actually just sold my Manchester and bought a new Jotul F45. The Manchester was just too much heat for my 1800 sq ft, well insulated new cabin. A bit smaller stove made for up to a 1500 sq' home, but it unbelievable how it heats.
Good luck
Good luck
