After all I've dealt with trying to get this thing going, I might just sell it. I know they are capable of getting much hotter though. I'd really like to know why I can't get the heat up on it.
I'm now thinking that maybe this particular model doesn't draft well when rear-vented.
Part of the problem is undoubtedly the leaky, un-insulated house. Tighten that up, and you'll be better off, both winter and summer.
If you're gonna go to an 8" outlet stove, Bucks are made in Spruce Pine, NC, and there should be plenty of used ones available to you, either cat or non-cat. I had a model 91 at my MIL's on a 21' liner, and the draft was plenty strong. Bucks don't rear-vent, but a couple might fit into your fireplace, and they can be run as an insert, or free-standing.
You can probably swap stoves without much if any cash outlay..
Why did you end up moving the Heritage? Moved it to the room you spent more time in?
What kind of sq. footage are you trying to heat? Is it open and easy for heat to move around, or is it a chopped-up layout with high ceilings?
insulated 8" liner. Put it to work!
Go get a big stove that isn't plated with insulation! I'd put a BK King...put a damper inline, 40' is a whole lot of draw
You guys that don't like soapstone keep spouting the same line, "soapstone is insulation," but I don't think so. Stone merely takes longer to heat up because it stores more heat than steel, pound for pound, and a stone firebox is thicker than steel so it stores yet more heat. My stove has some double-thickness stone..like 1.25" with both layers. Once you get it loaded with heat though, it blasts it out as fast as it's loaded from the inside of the box. And the additional time to get the stone hot from a cold box isn't all
that much longer, compared to the steel non-cat stove I've run recently. They're all gonna take at least
some time to get up to temp.
Your BK is actually more insulated than other stoves when you consider the firebrick and extra "heat shields" they put inside the box. Peak heat output isn't impressive compared to other stoves, according to a few different users. The "insulation" would explain the anemic high-output EPA numbers for the BKs. The soapstone stoves you call "insulated," trounce them at high end. Even the little Ws Fireview, at less than half the firebox size, thrashes the King.
No, the OP's problems are not because he has a small soapstone stove per se.
