You'll speed up the drying of those indoor splits considerably if you have a fan running, directed at them.
The usual reason for having a baffle break is because you get careless and bang a split pretty good up against it. How long they'd last if you never did that ever, I have no idea. My old Tribute was around 10 years old and had been run 24/7 for four or five years before I clocked the baffle with a split and it broke. I now have a larger stove where I'm less likely to bang into the baffle, and I'm also now flat-out paranoid about not doing that.In climates where you burn 24/7, how long do these baffles generally last? How much do they cost?
$30 bucks isn't bad. But it does pay to be careful when loading wood.The usual reason for having a baffle break is because you get careless and bang a split pretty good up against it. How long they'd last if you never did that ever, I have no idea. My old Tribute was around 10 years old and had been run 24/7 for four or five years before I clocked the baffle with a split and it broke. I now have a larger stove where I'm less likely to bang into the baffle, and I'm also now flat-out paranoid about not doing that.
Baffles aren't all that wildly expensive to replace. I think the one I got for the Tribute was $30. It's not like the cat stoves, where the cat has to be replaced every few years for a couple hundred bucks, I gather.
The baffles don't normally wear out, they get hit and damaged. I got nearly 30 cords through my heritage and replaced it for resale since a new baffle looks real nice. At the time, about 3 years ago, it was about 70$.
I agree that it would be much better if these baffles were made of something more durable. A couple of non cat brands use a stainless steel plate with holes for the baffle.
I would expect it to last at least 5 yrs or more Dave. BK warrants theirs for 10 yrs and we have heard reports of >5yrs on several stoves including Jotul F12s.
Good news. Thanks for letting us know.Hi again, I thought i would give you guys an update on my stove. I was going to attempt a temporary repair to the the baffle but after checking it further i found it was a in a lot worse condition than i thought. The whole section between the middle and rear airtubes was missing. What was there was very rotten and just fell apart when i later replaced it. The inside top of the stove above the baffle looked like the old popcorn ceilings. It was pieces of the baffle that some how got stuck there. It brushed right off. So anyhow I ordered a new baffle which took awhile to get but its in and the stove is working a lot better. I figure i will consider it a normal wear item and plan on replacing it every 4-5 years. The stove does heat up a lot quicker again. Also I resplit the would i had smaller and that helped get the fire going easier. So i want to thank all the guys here for their help and suggestions. This has been a great experience on this site and i will look at it in the future for good reading and knowlege thet people have to share.
