How do I know if the insides are ok? Is there something specific I should look for? It looked ok to me. And he seems like a pretty reliable person.I think it's a great deal if the insides of the stove are ok. Maybe the soot will wipe off with a little elbow grease, don't know.
Probably the coldest it gets here is around 30 more or less. And my house is less than 1000 sq ft. upstairs. Wouldn't the stove stay pretty hot even after it burns out?
Thanks
Thanks
I've already noticed that the heat of my Jotul...hangs onto that heat for hours after the fire is out.
Thanks
Mi that emissions sticker means 1990 EPA phase II testing was met nothing to do with age of stove- serial no. sounds reasonable for 8-9 year old stove it was high 20 thousands when I last sold Jotul (3 years ago) The F3 CB (cleanburn) came out around 1997-98. It was a cat model prior to that. It has the one piece sec baffle in the top versus air tubes, an open ashgrate design, and the air start switch in the middle of the front door. Single sliding air control upper right on front face, curved steel handle with wooden knob.
Nothing beats looking at the stove- if the stove was not used properly, the insides will say, bowing of the ashgrate or sec burn bowing up (this indicates someone ran with ash door open- had wet wood, and opening ash door gets it going however that is very detrimental to stove). Good luck with it, Jotul makes great stoves... still very well logistically supported too.
Stovelark
Enviro EF3 FS Pellet
Enviro Empress FPI AC pellet
Enviro 1700 Kodiak FS wood
The F3CB and the Morso 2110 are perfect stoves for folks that can get up to pee in the middle of the night, and can go right back to sleep. I definitely am not one that can do that. Once I'm up, I usually stay up.
Yes for the stoves I mentioned. However, the 3TDIC was an earlier attempt at making a compliant stove. I haven't owned one, but the word here is that this model wasn't Jotul's most successful design.
