I may try that. " renegade mode" if i remember back a few yrs. Controlling the heat via feed rate.I also didn't like that I was heating the outdoors at times so did some experimenting and found what works best for me. I normally let the stove run off the thermostat, but there are times that is inefficient and makes room temps fluctuate wildly.
I can keep the rooms at a constant temp during really cold days/nights (when the stove starts back up just at the end of the shut down) by using the feed dial instead of temp setting. I use stove temp / auto mode, with the temp dial at 6. I don't need big heat when the house is at temp, just constant heat and a feed rate anywhere between 0.5 and 1.5 usually does the trick. Using this method, the living room will stay about 73-74, the office (middle of house) at 69-70, and the bedrooms 66-68.
I find the flame is further forward in the pot as opposed to the deep throat burn of a maintenance mode when using room temp / manual. So, my thought is it would be more likely to cause a problem with the auger the other way. But, what do I know? I'm just guessing and really, that isn't any part of the equation when I burn this way.
. its why i dont use it.
