Hi all,
This is my first post on this forum, so a quick "hello" is in order. I spent a lot of time browsing this forum while I was making a decision on which pellet furnace to purchase. So, thanks to everyone who has contributed to this forum thus far!!
I ultimately decided on the Harman PF120 for several reasons. But, ultimately, it came down to the fact that it was the only PF that was sold by retailers in my area. Purchasing a PF of any other brand would have meant being 100 or more miles away from the retailer, and when it came down to considering future servicing needs that wasn't something I wanted to entertain.
My home has an oil furnace, which I decided to keep as a backup to my PF. My PF120 was installed just about a week ago. So far I'm super thrilled about the heat output I'm getting from the unit. It's nice to finally be able to turn the thermostat to where my family and I want it to be, and not having to fear seeing the oil truck come by and see my hard earned money go up in smoke. We were all so sick and tired of freezing our tails off during the winter due to having to keep the thermostat so low to be able to (barely) afford the oil. I estimate my annual heating costs will go from the $2500 - $3000 range burning oil to the $900 - $1200 range burning pellets.
For those of you that have experience running a pellet furnace, I have a couple of questions:
Here are a couple of pictures of my PF120:
![[Hearth.com] Harman PF120 installed - some questions on PF usage [Hearth.com] Harman PF120 installed - some questions on PF usage](https://www.hearth.com/talk/data/attachments/148/148200-d5cc16e32ccca8d4e7517741669d768d.jpg?hash=u_oqXBe4kI)
![[Hearth.com] Harman PF120 installed - some questions on PF usage [Hearth.com] Harman PF120 installed - some questions on PF usage](https://www.hearth.com/talk/data/attachments/148/148201-43e362cc25645db9ca1ad753803487ce.jpg?hash=3lDkf_TrsV)
(One of my kittens couldn't help but be in the picture
- Is it normal for the furnace to run hours on end? Up until I moved into this home about three years ago, I've spent my entire life in homes that run on natural gas. Both gas and oil furnaces turn off once the thermostat's set temperature has been satisfied. The PF gets the house up to the desired temperature very fast, but then continues to run for several hours (usually 3 - 5 hours - some times longer, and some times shorter - but that's the typical range). The flame definitely quiets down during this time, and the retailer told me this is normal for a PF. But I wanted to double check that with all of you out there. It would be nice to hear that this is normal for the operation of the PF. I figure this is because of the amount of pellets it consumes as it's getting started, and by maintaining a smaller fire it'll ultimately use less pellets in the long run? While the fire was lit the fan was running continuously up until yesterday when the retailer changed settings on my fan/limit switch. Now it cycles on and off after the thermostat temp has been met, which I'm honestly not a fan of. I can hear the pellets being fed into the furnace, so my thinking is that I might as well have the fan blowing and get my monies worth rather than have it just make a nice little fire for no one to enjoy.
- How much, if any, smoke/wood smell do you get throughout your house? We get quite a bit of smoke/wood smell throughout the house while the fire is going. It's particularly strong when the furnace first fires up, and then it scales back a bit and remains continuous while the fire is lit. I do not have any visible smoke anywhere (which is obviously a good thing), but I wasn't expecting to smell this much wood/smoke odor. I also cannot feel or see any exhaust coming out of the vent pipes, so my theory right now is that some smoke is making its way from the burn chamber and into the blower chamber. The other thing I'm theorizing about is the length of the fresh air intake pipe the contractors installed. The manual says to have a run no longer than 15 feet, and (after a rough measurement) mine is somewhere in the 18 - 20 foot range. I figure that would have more of an effect on the effectiveness of the fire itself, but can this possibly cause the burning to have other bad effects that might cause my smoke odor issue?
