I was reading the literature about Harman PC45s and in it they said you could remove the burn pot and install a burn pot from a p61 if you were going to burn straight pellets. I never heard of this being done but I wonder if you could get 61,000 btu's out of it by doing this? The bolt pattern is the same.
I would assume you would use that pellet plate that covers the exh fan if you were to do this. May have to play with the dip switches also.
Just curious if anyone has done this and the results they got? That would be a cheap way of getting more heat out of the 45. It surprises me that Harman recommended this so evidently it must work.
