easy way to rule out the ESP? what if i switch to room temp instead of stove temp?
covering the intake not sure how to go about it correctly. there is a fan that faces the vent and into the back of the stove i assume leading to the burn pot feeding the holes. do i cover the fan? the stove side on the pipe itself?
ESP is used all of the time you can't rule it in or out by turning a switch.
You may have damaged it.Shine a flashlight in the exhaust path and see if it's still there.To remove it take the rear covers off and look for the wire coming off the exhaust.You will need a 1/4" socket to remove the nut.it in the manual it appears close to the front, would i be able to easily see it with a flash light and clean it out? is it recessed or dangling int he air? i jammed the scrapper in there pretty good i hope i didnt cut it right off
So its the big fan i want to block flow from correct? not the smaller one? honestly havent noticed a difference on either. I have 60% covered ont he large fan and still insanely aggressive
