Okay. Combustion blower is acting spuratic. Random bursts of power then it slows way down. How can I adjust this on the circuit board?
What generator were you running it on, maybe make/model ?Definitely - and I agree for sure but this time it’s very drastic. Sorry if I’m talking around in circles. I won’t have a fix until tomorrow and that’s okay! My guess is because I ran it on generator that I fried the board and that it is just not responding well. Thanks guys
Use 12 gauge or lower number for extension cord, depending on length.. Lower number equals the bigger wire for current loads..Okay guys. It was the circuit board!! My amazing dealer came out and replaced it. Our guess is due to the long run of extension cord I was using on my generator it messed the circuit board up and everything was getting low voltage. Glad to have this behind me -
Never seen leg levelers. I have mine sitting on a tile pad..Ty! After spending so much time on the back of the stove I noticed my p68 doesn’t have any leg levelers installed on the back which could certainly be making it louder because it’s steel that sits on tile! Do Harmans have leg levelers or do you have any idea on something soft and non combustible that I could place between the stove and the tile?
Sitting on tile will not make it loud. It is heavy steel. They all sit on tile, concrete or stone. The tin on these stoves are well secured and typically does not rattle . You must run these on an inverter generator or the board can get damaged. It only pulls max of about 410 watts which is only about 3.5 amps. I would say the generator was the culprit as opposed to the cord.Ty! After spending so much time on the back of the stove I noticed my p68 doesn’t have any leg levelers installed on the back which could certainly be making it louder because it’s steel that sits on tile! Do Harmans have leg levelers or do you have any idea on something soft and non combustible that I could place between the stove and the tile?
