I have a Harman p38, that was installed new this fall, with outside air kit. I notice/hear the air coming in from outside air vent creates a cavitating sound, and movement. The outside air is a straight shot to the stove with flexible pipe connected to the vent and stove. If I'm outside I can sometimes hair this vibrating sound and inside it can be distracting. Is there a way to adjust this flow so it stops this? I usually put the burn pot cleaner tool on top or against the air pipe to reduce the sound/vibration. I know there is a trim pot adjustment for this stove that is set at the factory, and usually checked by the installer with a draft meter of some type. Anyone have this problem? Any fixes? Thanks, Ed
