maglite67 said:Give the stove a good cleaning refer to your manual. make sure you remove all the plates and clean behind the combustion fan. The only time you need to change the draft is if you are going up verticaly.
rickwa said:v ferdman, one more thing that very likely could be causing your problem that i had happen on a stove the other week. take shields off the back if you havent already. turn stove to test mode and check the rpms of the auger motor. it is a 4 rpm motor. if the motor is taking more than 15 seconds to make 1 complete turn the motor is getting weak or the armature needs taken out and cleaned and oiled. i have seen this situation more than once. and it only takes a couple of minutes to do. if the motor is running slow or starting slow it starves the stove for fuel. on a higher burn it is getting enough to mantain a fire but on low it is not enough feed. i forgot this is a gently used unit as opposed to new or i would have suggested this in the beginning. i would put money that this is you problem. you have been through everything else i doubt it is your hopper seal.
SmokeyTheBear said:"Electric motors either work or they don’t."
Not quite the way it works. There is after all those nasty things known as bearings, a bearing that is losing lubricant will tend to slow an electric motor down.
It is also possible that increasing voltage (after all that is how these puppies are controlled) will have results in the other direction. Motors are not binary devices.
RETIRED GVA said:I'll add here since you own a 87 I assume you know what you are doing with it since most non electrical types don't drop a couple hundred on a meter.
Not that this is related but check for a hot / neutral reverse on the receptical the stove is plugged into.
I would suggest that you hook up the meter to a neutral and the NO contact on the Vacuum switch and put the 87 in min/max timed mode and walk away.
You should have 120 on it at all times the combustion blower is running.
Most people here are leaning on something with the draft being off and I agree
RETIRED GVA said:Well since all you do is unplug the stove and plug it back in (you can just turn the knob to off then back on for the 6 blink) it's likley not a bridge in the hopper.
Usually the cure for this is to insert your hand in the hopper and stir the pellets.
RETIRED GVA said:I just retired my Fluke 77 after 20 years of use and now use a 12 on the floor and a 87 at my desk.
RETIRED GVA said:There are several things that cause the 6 blink
Board
ESP
no pellets
The stove actually is sensing poor combustion.
ESP has been changed
that leaves the board or no pellets......Usually
reason for no pellets
Auger motor is bad
bad combustion blower
bad vacuum switch
plugged exhaust
leak in the system
or any combo of the above
we just need to break down all the above
if you're vac switch opens while the combustion blower is running then
you have a weak draft caused by a failing comb blower, plugged exhaust, leak somewhere in the negative pressure fire box etc.......
It's possible that you did get a bad ESP replacement....Though doubtfull
If it was a small vacuum leak then turning the draft pot all the way down would trip the stove more frequently I would suspect.
I think that you may have a bit more natural draft right now due to the cold temps that have arrived in Mass, (though i've been wrong before)
I think the vac switch IS opening for some reason though.....
rickwa said:good point gva. between the 2 of you, you should be able to come up with a way to hook up a meter on the vac switch and record for a period of time to see if the switch is dropping out. the vac switch is in the neutral circuit going to igniter and auger motor. that would rule out the switch.
V have you tried any different pellets to rule out your fuel source yet?
rickwa said:in simple terms on vac question. the air and exhaust is being pulled out of the stove. the air inlet is alittle smaller than the outlet and the air has to travel through the passage ways in the stove which cause restriction, which cause resistance, which causes vacuum. it is a very small amount like .3 inches of water column
vferdman said:rickwa said:in simple terms on vac question. the air and exhaust is being pulled out of the stove. the air inlet is alittle smaller than the outlet and the air has to travel through the passage ways in the stove which cause restriction, which cause resistance, which causes vacuum. it is a very small amount like .3 inches of water column
Got you. Thanks for the explanation. I was just thinking that air in MUST equal air out, so where is the vacuum coming from? restrictions in the air flow the pressure will drop a little. Very little and hence the great sensitivity to minute leaks. If my fox worked (and looks like it did) the leak in the auger bearing assembly was truly minute.
SmokeyTheBear said:vferdman said:rickwa said:in simple terms on vac question. the air and exhaust is being pulled out of the stove. the air inlet is alittle smaller than the outlet and the air has to travel through the passage ways in the stove which cause restriction, which cause resistance, which causes vacuum. it is a very small amount like .3 inches of water column
Yes it only takes a little leak to cause trouble and the trouble can come in several forms.
You experienced one, there are others, the biggest one for puffer stoves is additional ash generation, poor ash ejection leading to burn pot overflow and fires in the ash bin or pellet chute and hopper.
