Harman Accentra 2 Free Standing (FS) - Blowing fuses / auger not moving
shubbah
12
Oregon
We have an older Harman Accentra 2 FS. My mother claims the auger quit working the other day. She tried to unplug and plug the stove back in and somewhere during that time it blew a fuse on the control board. Please note: this stove does not have an igniter. In addition, I installed a new auger and combustion motor that have been working fine the last 6 months. Since this issue occurred, I have:
  • Confirmed the auger moves freely once off the chain
  • Blew 3 more fuses trying to test if the auger would kick on
  • Installed a backup auger motor to see if it was the issue and both auger motors just turn very slowly, but do not actually turn enough to feed the stove
  • Inspected the wires in back and do not see any exposed/frayed/loose wires
My next thought is it may have a bad control board?
I'd probably make a fused 120V jumper from an old extension cord (10A 120V Fuse).Unplug the stove. Unplug the feed motor from the control card. Use the jumper hot and neutral to feed the auger motor. See how that goes. If it all seemed good, I'd get a board. Make sure to use a surge plug/bar for your stove.
If you do get a new card make sure to set the dip switches per your ESP probe type or you will get a fault. The card will come set up for red wired ESP which is the latest type.
Reactions: Ssyko and jackman
Do you use a surge protector on the stove?
Great question!
No, we have had the stove plugged directly into the wall for the last ~20 years and has not been an issue. I will grab a surge protector and test it. Thanks!
The surge protector will not fix the problem,but may prevent a problem with your new card (if you get one). You cannot test a surge plug/bar. If it has a light on it, then the light will tell you if it is still good.
Thank you for your reply - Makes sense - I have ordered a new control board off Pellethead/Earth Sense. I'll be sure to plug the new one into a surge protector.
Good. Don't forget to set the dip switches. If the board instructions do not include your stove/esp type let us know. I just posted a chart on one of the previous posts.
Reactions: Ssyko and shubbah
The reason I ask about the ignitor is I'm not aware of a manual start Accentra 2. Does you're circuit board have the option for an ignitor and just doesn't have an ignitor installed? Just thinking you may have wires in you're burn pot that are not connected and possibly causing a short and blowing the fuse.
That is a really good point. I kind of inherited maintaining the stove and a couple weeks ago I did a thorough cleaning and cleaned out the burn pot which was stuffed with debris. I did notice there are two wires in the burn pot, not connected to anything with exposed ends. If I recall correctly, the red light never turns on on start up that indicates the igniter is being used.
It does appear to have an older board on it. The replacement boards are a different model than is what’s on our stove. But it’s kind of odd that it could’ve ran for almost 20 years without short-circuiting the igniter if that is actually the issue.
Here is a picture of the board:
[Hearth.com] Harman Accentra 2 Free Standing (FS) - Blowing fuses / auger not moving
Reactions: Ssyko
The yellow wire on the plug is for the igniter. Light Blue is the other side going to the pressure switch (not to the board). If you don't want to use an igniter then you should disconnect those wires in the back at least. They go to quick disconnects. If you do that you could leave the wires going into the burn pot which would be handy if you decide to install an igniter to pull the new wires in.
Here is a picture of the board: View attachment 338196
Here is a picture of my spare igniter. I'm not sure if it would be the same as what you had. If you can see the wires in the burn pot then it seems they cut them off if they removed the igniter. When you change an igniter you pull the new high temp wires into the back of the stove as part of the job
  • [Hearth.com] Harman Accentra 2 Free Standing (FS) - Blowing fuses / auger not moving
Reactions: Ssyko and NS P-68
If you can trace those wires back to where they connect behind the stove and disconnect them I would put a fuse in your old board and try it. If you disturbed those wires while cleaning there is a good chance these wires have melted and causing a short which is blowing a fuse. Your old board may or may not be still good. Alot of times a short like this will take out the circuit board so you better be certain these wires are disconnected properly before you go installing a new board
If you're manual starting the stove and your switch is in the manual position , I don't believe the ignitor light will come on.
Personally if it were me I would install a new ignitor while your at it and at least have the option to use it. There are good videos online showing how its done.
I think you’re spot on. For whatever reason they cut the wires to the igniter in the burn pot and took out the igniter as the wires in my burn pot look exactly like yours.
This was my late stepfathers stove, so I’m not sure what the back story is on it.
Sometimes when you start working on an existing used machine/stove ect there is a learning curve. It is easy to buy a new stove and you don't have these sort of issues. However, eventually something will go wrong, and this is why I like helping others as I am learning as well.
NS P68 is a sharp guy for picking up on this issue. I think since you are in this deep with a new card, you should go for the igniter. The problem may be that there is a bracket that may be missing that the igniter goes on? You don't need to do it right away, just isolate those wires and get it up and running as is.
Update:
1. Unplugged the igniter cables in the burn pot at the quick detach.
2. New board arrived. Set the DIP switch setting to my stove (Accentra), installed the new board , powered it up and it blew a fuse on the new board. Also made sure the stove was plugged into a surge protector.
3. Installed old board (since new board fuse is blown and uses a different fuse) and decided to disconnect the combustion blower to see if that changes anything. Well, the auger motor still does not turn, but no fuses are blowing. I think this must mean the combustion blower is the culprit blowing the fuses? Since the auger motor is still not turning, does it require the combustion blower to be on in order for it to feed?
This combustion blower is like 6 months old, but is not an OEM blower. (ordered one initially, but this is what they sent).
Reactions: Ssyko
Yes, your combustion blower will need to be running in order for the auger motor to turn. Auger motor only receives power when the vacuum switch closes and that is done by the combustion motor.
If you have an old piece of extension cord you could make up a test cord by crimping a set of those quick connects and test each motor individually. Just make sure you unplug the stove first.
Highly likely the combustion motor is the culprit in you're case if it immediately blowing the fuse.
Update:
Sounds like perhaps those wires for the igniter are grounding on on metal. Go back and make sure there are no wires touching metal. Any exposed wires need to be taped up. Double check those combustion motor wires and try and test the combustion motor like NSP68 said. To make a test wire use a 2 wire cheap cord and add a 10A 120V fuse to the cord. You could also test the motor with an ohm meter. Let me know if you have a meter or if you are able to test electrical as it can be dangerous if you have not done it before.
I am reposting that chart re dip switches
Your problem might not be the combustion motor. Maybe it did start up and the pressure switched closed sending voltage to the igniter wires (which should be isolated) and auger. Did you check the auger motor before to make sure it worked (by jumper) ?
I thought the igniter wires may be grounding, that's why I disconnected them at the quick disconnect, but you make a good point to tape them up, just in case. It also doesn't explain that when I disconnected the combustion blower than no fuses are blowing.
To test the combustion/auger motors with an old extension cord, how do I add a fuse to that extension cord? Would I use an inline fuse only on the positive wire? I am a novice when it comes to basic electrical work.
I forgot to mention, I hooked the combustion motor back up and I removed the front panel inside the stove to confirm the combustion motor fan spins on start up, but quickly blows another fuse on the control board.
Disconnect the wires to the combustion motor using a lamp
cord. Attach the 2 wires; plug in the lamp cord. Does the motor spin?
If the motor is bad it will not spin or spin very slowly and get very hot
If the above happens, replace the motor. There is. no need for an inline fuse if
the motor draws too much amperage. The house breaker will flip
When you disconnect the combustion motor, the vacuum switch cannot close, and the auger motor will not have power. (and also the wires for the igniter would have no power.
You would buy a 120V inline fuse holder and some 10A glass fuses in the "hot" side only. I would not recommend it unless you had some experience as 120V will kill you.
As you can see the combustion motor might be OK, you need to make sure the unused wires are taped up and test the auger motor as we mentioned some time ago. Get some help with the electrical and jumper the auger motor on and test.
I am understanding now that I'm getting in the territory of not fully grasping what I'm doing and likely dangerous, so I think I'm going to throw in the towel.
I did as Joneh suggested and used an old extension cord to test to combustion motor. It ran fine for a few minutes. I decided to try the auger motor and it started turning, but then sparked and the plastic cover caught fire. I imagine i've burned that motor up. I have an old spare auger motor i can swap (which I tried earlier to troubleshoot) and it didn't fix the original issue of blowing fuses, so I think I'm back at the original problem with a burn up auger motor.
That's why we asked you to test the auger motor some time ago to make sure it turned freely and fed pellets. Probably the auger motor is jammed and the motor stalled. That's why I use a fused extension cord, as a stalled motor may not trip a 15A thermally activated house breaker. It will just sit there and catch fire. That's why the stove fuse is 6A usually and Glass, not a breaker. Don't give up. Unhook the auger motor and see if somehow you can move the auger shaft. When you take the motor off see if it spins freely.
Heat pumps suck when is really cold, and don't work if there is no power. I have heat pumps, but installed a pellet stove and love it.
I have it running on a battery that I can recharge
I reread your post and you have chain drive. I was down looking at my spare, and it has a gearbox attached. I cannot turn the motor shaft myself, I would have to plug it in. Try and determine why your motors will not turn, and take them apart if you have to. The motor could have overheated, or the bearing(s) failed.
Reactions: shubbah
