It stops 100% if I even slightly open the door or the hopper. I'm assuming no one's found a fix? It's annoying when it happens.
			 Happens with my Englander 25-PDVC too.
 Happens with my Englander 25-PDVC too.Here are my thoughts;
1.) When I installed mine I used leftover 4" intake for the oak as opposed to the 3" the manual calls for. I need to replace with 3", and have been told to run it at least 6' up into the chimney.
2.) I've read that the draft needs to be set with a gauge to I believe between -25 and -35 (page 27 in the manual. I have not been able to find this port, but haven't made it a big priority yet. My "rumble" problem is more persistent at idle, or low draft.
...So I think I have enough air, maybe too much.
I don't know how long the warranty is. It started making a "hum" whenever it was on. I knew it had to be the combustion motor after listening to it for a while because that was the only thing running. It had bad bearings, and besides the noise the stove worked fine when in use, right up to the day I replaced it.
I am no expert it was just a thought. Perhaps it is the other end is there any obstruction? That points to the back draft door opening and closing.
Does smoke come in your house(more than you think would) when you open the door?
The bolt in question is located in the front left corner looking at the stove. It is under the ash pan, believe it is a 3/8" coarse bolt-9/16" head.
Open the door and remove the ash pan. See bolt in stove floorNo obstruction, cleaned regularly flu and all. No smoke has ever backed into the room, door or hopper open. I've even accidentally left the hopper open one night and had no issues. I read when cleaning to put in "test" to draw up any soot. Works great.
Is this on the inside of the stove, like open the door to get to it, or behind the bottom "molding?" that you have to remove to pull the stove out? Any chance you have a picture, cause I'm feeling stupid/blind at the moment....
Thanks guys!
Remove cast trim at bottom of stove and somehow get the adapter at the end of the hose into the test port. Door closed while running in test mode. I've never done it myself. I just picked up a used accentra insert and saw where it was while pulling stove apart. I'd love to see a pic or 2 of what people use as an adapter to do this. I may be at my dealer today snd if so I will ask
Yes it's under the panI pulled the trim, it's currently running so I didn't remove the ash pan. I don't see why removing trim would have anything to do with it? I see nothing. I'm thinking once I remove the pan I might, but I'm still not understanding the procedure for this test.
I had the combustion blower bearings squeal within two months of installation. Dealer came out and swapped out the blower and problem solved.
Thanks, at least I know I'm not crazy. I wonder if they just use crap bearings, or maybe the heat gets to them? I looked it up, I installed this blower in Jan of this year. I could of waited for the warranty guy, but he was 3 weeks out. If I can't get it replaced, I'm going to change the bearings with something heavy duty.
On another note, I added something else to my post up top that I did to the stove as well. Connected it to the the thermostat. So far, I really like it. This way if I forget to turn the stove down at night, I'm not out of pellets in the morning. My hopes are that it will save some pellets this year.
FWIW, the replacement combustion blower has been running fine for two years. It's an easy install so if you're comfortable doing that, remove the blower and bring it to the dealer for replacement.
Well sorry about your problem,but,in my opinion,is rare.Even with harman suppliers of the motor,I really cannot say anything bad,mostly very high quality,from what I have seen,but problems of this sort seem to rear there head mostly in fireplace installs.Depending on design/airflow,basement-foundation,you may have a moisture thing happening,affecting the brgs/and seals.Have never put brgs in a harman combustion motor,but have at least one in parts box,if you want me to take it apart and measure brgs,let me know.
Do not want to go there,my accentra is very quiet,BUT my austroflamm is extremely quiet,but much older!LOLI appreciate your offer, may take you up on it depending on what the dealer does. I agree about everything being top notch, nothing else with the stove has been an issue. Flawless. I also thought maybe a moisture problem, but I have the top plate sealed with heavy roxul insulation over top. And the combustion blower is the only thing to go, both distribution fans are perfect. No surface rust on anything, not damp at all.
I'm really hoping I'm just unlucky and it's a fluke. I shouldn't have to change the bearings, but at some point the dealer isn't going to cover it anymore (she was pretty skeptical on the phone today). I'm not even 100% they'll stand behind this.
Except for the higher than acceptable hum, the stove runs perfect.
 The pictures that I posted in the install are of it directly next to the TV, and we don't have any issues at all. Sometimes I turn the distribution blower down some, but other than the stray pellet getting crunched everything is (was) very quiet.
 The pictures that I posted in the install are of it directly next to the TV, and we don't have any issues at all. Sometimes I turn the distribution blower down some, but other than the stray pellet getting crunched everything is (was) very quiet. So now I'm in for either a replacement motor, or replacing the bearings.
 So now I'm in for either a replacement motor, or replacing the bearings. We use essential cookies to make this site work, and optional cookies to enhance your experience.
