P.S. - Just ordered my liner from FiresideChimneySupply, price was good, free shipping and I saw a 10% off coupon on the web....we'll see.
Perhaps not clear from prior posts, the chimney will have a 4" exhaust tube from the stove to the crown (top/exit of the chimney). The exhaust tube is non insulated and the chimney (with clay tile) is closed/sealed at the crown and damper. The Harman manual states that an OAK tube can be run up the chimney to within 4' of the crown. This confuses me because if I am sealed at both ends, there is no fresh air... so the answer is or assumption, there is fresh air to draw - presumably from the crown cap. Again, presumably, the thought process to seal both ends is to "heat" the chimney pathway for the exhaust tube to better draw. I would think if the exhaust tube was insulted, then perhaps you could have the top crown plate vented as I have seen on various threads to give air to the OAK intake. Regardless, my stove installer is sealing both ends, using a non insulated exhaust tube, and I will not have outside air.I have the same issue you do and
I'll be really honest here; I'm installing my first pellet stove in a chimney, so your terminology is evading me. I know the damper is the metal door I have pictured above, and I would assume the crown is the top? At any rate, I don't think it would help the natural draft. In a wood stove, this would probably be horrible/illegal, but with a pellet stove it's power vented. So natural draft is only relevant in the event of a power outage, in which case I'll have an $80 APC (American Power Conversion) model #BE750G (on Amazon) to run the exhaust while the unit slowly powers down.
I'll admit that there will probably be more creosote build up in the liner because of the cooler temperatures I'll be introducing to the chimney/liner. If it wasn't ridiculously expensive I might wrap it in insulation, but I plan to just have to clean it more often. (What, once a year? Shouldn't I be doing that anyway?)
I hope I answered your question, but please realize that this is based on my opinions from stuff I've read,....so take it with a grain of salt.....or maybe not at all....
I too have commented of a low rumble since my 52I install last March. I think It is the exhaust blower as I can still hear it when the blower fan shuts off. Your insert looks great also!So... loving the stove, however, I get this subtle rumbling noise (distant train?) when it's rolling full blast. A friend of mine works at the local dealer, he said they are replacing a piece on the back of the units before they are even installed to fix this. Does anyone know what that might be?
