Just purchased this rear-vented stove. I have a few questions as this is new territory for me and I want to be sure I do the right thing and the stove is safe to use.
Anyone able to tell what year it is? How to determine if the name and trees have been painted over OR if there's nickel under the paint? There is some very mild rust under the lip of the top and inside the doors and wood box - should I work on this rust then paint with what Coaly has recommended OR just leave it alone? Inside there are plates welded on that appear to be for sitting a baffle on - is that correct? Bricks are cracked (none are missing) - is it safe to use as is OR do they need to be replaced? If need to replace, how do you get them out and new ones in with them being behind those welded on brackets? Anything else I should know about? Thank you!![Grandpa Bear - restoration questions Grandpa Bear - restoration questions](https://www.hearth.com/talk/data/attachments/286/286170-2d3a69b8189df2766412ace7ffd90f69.jpg)
![Grandpa Bear - restoration questions Grandpa Bear - restoration questions](https://www.hearth.com/talk/data/attachments/286/286171-89a9ef1ecf87eaeaaad0a20c4edc74a9.jpg)
![Grandpa Bear - restoration questions Grandpa Bear - restoration questions](https://www.hearth.com/talk/data/attachments/286/286172-e8d239aa1bcaf7bda295c59e593b6c23.jpg)
