got a price on a o.w.b.
master of fire,
read that what a mess. dealer did not come to home & do a heat loss.
nford,
yes. i have not found anyone around here with a gsser, this county is mostly rural, i have seen am lot of owd in the yards while driving around.
after all the comments i`m back up on the fence. not sure if i mentioned it , home is { total 3700 sf. ft. barn is 3500. i won`t be heating all the barn it wiil be sectioned off to some xtent.
herman
Find out what the heating load will be for both buildings.
What will be th method of heating both buildings, forced air, raidiant etc etc
Then you need somewhere to locate the boiler, presumably in or near the barn, where is the wood supply.
No matter what boiler the re will be trenching and insulated pipe, the size will depend on the heat load.
If you end up going the OWB route, there are better ones out there. And better dealers.
Insulation and infiltration should be addressed first, smaller boiler, smaller pipe everything gets more manageable.
woodsmaster said:
DONT USE THE BUBBLE WRAP PIPE no matter what you go with, You will be heating the ground. Read the sticky on underground pipe at the top of the boiler forum page. You will pay a lot more for good pipe but burn a lot less wood.
Seconded, a buddy of mine is melting snow with that stuff, buried 24" under the ground... don't buy it!
