Gooserider has moved to a new room.
His new room is 925W.
His new phone number is 617 573 7656.
Mary-Anne said:If it is okay with everyone, I would prefer to go with the tile.
I do plan to have one of those automatic shower cleaners.
I have already done the same in the toilet.
Someone, probably Dune, should call the tile shop on Friday and talk to them and make sure there are the correct expectations on what will be done by whom.
BeGreen said:It's best to approach design with an open mind. Keep all ideas on the table and keep them coming. Some will work better than others. But leave the past design in the past. The future needs for this space have changed and should be the guiding criteria.
I need to head into town and start on some plumbing projects. But before I go, here is a for instance drawing. Note that this is just one possibility. The toilet has been moved to the tight sink location. The advantages are that a grab bar can be put on the wall to make it easier to get on and off of the toilet. The cold water plumbing is already there and it's not a big deal to move the toilet drain over a few feet. The sink area is now generous and allows easy access. There is an open shelving to the right to allow easy access. The shower area is generous and safe. A trench drain will prevent any water from going beyond this space.
Dune said:Goose, what are your drain pipes? PVC, ABS, copper or cast iron? I will be doing all the new work in PVC, but will have to adapt to whatever is there. If I know what you have, I may be able to scrouge up some otherwise expensive adapter parts (if it were copper for instance.) If cast iron, I will need to bring a bunch of gear I don't normaly carry around.
Also, abs is getting hard to find.
I don't want to change the location of any of the fixtures, as I agree it is important to be able to transfer on from sideways to at least some extent. Currently in the rehab, I approach the toilet chair sitting over the hopper such that the front corner of the chair is at approx right angles or a bit less to the toilet chair, and then slide board over the corner onto the chair, and back. Works pretty well, and I should be able to do the same thing with the current home layout.TreePapa said:BeGreen said:It's best to approach design with an open mind. Keep all ideas on the table and keep them coming. Some will work better than others. But leave the past design in the past. The future needs for this space have changed and should be the guiding criteria.
Pardon me for jumping in late and I apologize if this was addressed later in the thread. For some reason, this thread is taking forever to load and I wanted to respond to this.
The toliet area in that plan does not allow sideways transfer, which may or may not be necessary depending on how well Goose can get in and out of the chair. I can't readily imagine a layout which would allow sideways transfer, but it is something to consider.
Also, I would stongly recommend ditching the old toliet and getting a 16" high "accessible" toliet; it makes a hugh difference for folks w/ disabilities.
I will post more later on what we went through getting the "cottage" ready for my FIL coming back from rehab in a wheelchair.
Peace,
- Sequoia
Hunderliggur said:If the tub is cast iron you can break it apart with a sladge hammer.
BeGreen said:How did office and bath doors work for you?
Hunderliggur said:Looks like te Lay-Z-Boy got a good workout!
Flatbedford said:Hey Goose is this of any interest?
http://newyork.craigslist.org/wch/for/1725625006.html
"Over 50 feet modular steel wheelchair ramp system by American Ramp Systems.
With custom 5 foot platform and top and mid handrails on both sides.
In great condition.
**Pick up only. Buyer to disassemble and transport.**
Original purchase price - $8,000
Price Negotiable
Call Artie at 914-954-1330"
It can't be far from me.
