Huntindog1
BB I always knew you were smoking somethingDifferent smoke for different folk.
Next year I will be getting a Jotul Oslo, and will build a solar powered wood shed so that I can get my firewood down to the low humidity that these EPA stoves demand.
I was wondering when that was coming. Where's Pook when you need him...Might as well top it off with a Magicheat add on....
Loaded a 40 pound bag of anthracite coal 11 hours ago wow I'm really wondering how many days it will go the way its burng wow.
Stainless steel liner but no baro damper.They actually are pretty good coal stoves that is what i would be burning it i had that beast. From what i have seen they work way better for coal than wood. Do you have a barometric damper on it now for coal? if not get one it is dangerous without one. And what liner do you have it hooked to?
Yeah what kind of stainless? Coal will eat allot of ss and if you are burning coal you need a baro but you need to pull it when you burn wood of you will have a gooey mess in your chimney. More than normal with one of thoseStainless steel liner but no baro damper.
Its a UL listed stainless steel factory built chimney burnt a lot of soft coal in 09 with the first coal burner.Yeah what kind of stainless? Coal will eat allot of ss and if you are burning coal you need a baro but you need to pull it when you burn wood of you will have a gooey mess in your chimney. More than normal with one of those
But about the baro nothing like feeding room air in to a roaring chimney fire no thanks. ill stay with my manual pipe damper.
I understand what your saying when my chimney was install it was with my first stove the wondercoal back in 2009. Now the baro I have read a lot of bad things about it.You need a baro to keep that coal fire from over drawing and seriously over heating the stove they are recommended for all coal stoves but i agree with you about baro dampers on wood they should never be there. We always have our customers pull the damper and put a cap on when they burn wood. I have seen lots of coal stoves destroyed when they over drew because of no baro. And as long as your chimney is 316 ti it should be good but if it is a wood chimney with 304 liner you could be in trouble pretty quick.
On wood absolutely i would never put one on a wood stove and try to get customers to take them off when ever i see them on one but you really should have one on for coal that is one of the problems with combo unitsNow the baro I have read a lot of bad things about it.
Also I burn more wood then coal. The baro would be a pain. Plus all the bad things I have heard of with those. my MPD does the job.NOTE: A draft reading of ..025 W.C. is suggested for proper burning of this unit when
using bituminous coal as fuel. When using anthracite coal, this draft reading is a
minimum reading.
This is out of bucks manual the only way i know of to maintain a specific draft which is what they want is to use a baro damper. Any other Method will allow the draft to fluctuate allot. If you are burning soft coal it wont over fire as easily as it does here with hard coal but it can still easily happen. I am only trying to make your install as safe as possible for you not trying to give you a hard time about it.
Please enlighten us on the bad things you've heard about them when installed on a coal stove.Also I burn more wood then coal. The baro would be a pain. Plus all the bad things I have heard of with those. my MPD does the job.
